TRD3000GT Posted November 16, 2004 Share Posted November 16, 2004 Ok all, I got a set of these today but the both holes are no where near correct for the small drill holes in the supra pedals. I have put on the brake and the clutch one with heay duty double sided duck tape and one bolt. Bottom left one to the bottom left hole. They are very secure. And for good measure might drill another hole to get another bolt in to each one. How on earth am I supposed to fit the accelerator one though? There are no holes in the pedal and Im not sure from feeling behind, that I can just drill holes to fix it on? http://www.mvpmotorsports.com/merchant/catalog/jdm/u/sparco/cfpedals.jpg Link to comment Share on other sites More sharing options...
SimonB Posted November 16, 2004 Share Posted November 16, 2004 Yep, I haven't got these exact pedals, but they're all the same, you drill 4 holes in your clutch and brake pedals and bolt them on. Bit awkward drilling holes in your brake and clutch pedal. The throttle pedal you can attach using self tappers (which were included with mine) as the pedal is plastic. The good thing about it is that you can adjust where the pedals are in relation to each other to make heel and toeing easier before you drill the holes and bolt them. Link to comment Share on other sites More sharing options...
