Sandy-m2 Posted August 27, 2007 Share Posted August 27, 2007 Say you had 1 Jack and 4 axle stands, How do you SAFELY put the car on the 4 stands. Apologies if this is a daft question:rolleyes: S Quote Link to comment Share on other sites More sharing options...
MrRalphMan Posted August 27, 2007 Share Posted August 27, 2007 I'm not sure it can be done safely, deffo can be done, but safely? Quote Link to comment Share on other sites More sharing options...
merckx Posted August 27, 2007 Share Posted August 27, 2007 A trolley jack? Quote Link to comment Share on other sites More sharing options...
MrRalphMan Posted August 27, 2007 Share Posted August 27, 2007 Ah... Trolley Jack, that's a different matter. Much easier. But the standard jack.. watch out. Quote Link to comment Share on other sites More sharing options...
Sandy-m2 Posted August 27, 2007 Author Share Posted August 27, 2007 Sorry yeah, trolly jack - not standard one Quote Link to comment Share on other sites More sharing options...
Lewis Posted August 27, 2007 Share Posted August 27, 2007 Big planks of wood normally work, chocked front - raise rear. Depending on the angles then you may want to use the lowest settings....I wouldn't want to do it at all though. Can you not get some ramps? Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted August 27, 2007 Share Posted August 27, 2007 Its not something i often do having ramps, but i would say front up first, one side at a time, and then, iirc, the diff is the rear jacking point, so jack the diff and pop the stands under. Under the diff wont allow the car to twist itself off the stands. Try to get axle stands with decent wide bases too... Quote Link to comment Share on other sites More sharing options...
Sandy-m2 Posted August 27, 2007 Author Share Posted August 27, 2007 i'm not against getting ramps but could i get the whole car up on ramps - product suggestions please??? Quote Link to comment Share on other sites More sharing options...
Lewis Posted August 27, 2007 Share Posted August 27, 2007 Its not something i often do having ramps, but i would say front up first, one side at a time, and then, iirc, the diff is the rear jacking point, so jack the diff and pop the stands under. Under the diff wont allow the car to twist itself off the stands. Try to get axle stands with decent wide bases too... ^^ makes sense. Quote Link to comment Share on other sites More sharing options...
Sandy-m2 Posted August 27, 2007 Author Share Posted August 27, 2007 Thanks for the hints so far guys. Quote Link to comment Share on other sites More sharing options...
Lewis Posted August 27, 2007 Share Posted August 27, 2007 i'm not against getting ramps but could i get the whole car up on ramps - product suggestions please??? Drive the front onto the ramps and jack in the centre rear jack position marked above. I think that was the suggestion. Ramps level off on the top so would be the same as jacking it up - just much easier. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted August 27, 2007 Share Posted August 27, 2007 Drive the front onto the ramps and jack in the centre rear jack position marked above. I think that was the suggestion. Ramps level off on the top so would be the same as jacking it up - just much easier. That was the suggestion Quote Link to comment Share on other sites More sharing options...
Sandy-m2 Posted August 27, 2007 Author Share Posted August 27, 2007 ahh i get you. Quote Link to comment Share on other sites More sharing options...
Scooter Posted August 27, 2007 Share Posted August 27, 2007 I would use your scissor jack in the boot to jack one front corner up.......place the axle stand under on its lowest setting and do the other side. Use your proper jack (with wood/foam pad) on the rear diff going in directly from behind and jack the rear up in one go and position the rear two stands. You can then raise them from there to the desired height. After its down on the stands i always try and have the jack jacked up just to the point of contact somewhere in the area i'm working just as extra security........... Quote Link to comment Share on other sites More sharing options...
Sandy-m2 Posted August 27, 2007 Author Share Posted August 27, 2007 Thanks guys that helps lots. Quote Link to comment Share on other sites More sharing options...
patrikbrunt Posted August 27, 2007 Share Posted August 27, 2007 when i tried to drive up my ramps they kept skidding along the drive! isnt as easy as with a fwd car...! Quote Link to comment Share on other sites More sharing options...
CarlT67 Posted August 28, 2007 Share Posted August 28, 2007 when i tried to drive up my ramps they kept skidding along the drive! isnt as easy as with a fwd car...! Lol...I can just imagine the trouble you could get into doing that Quote Link to comment Share on other sites More sharing options...
Guest CoolsBlue Posted August 28, 2007 Share Posted August 28, 2007 i did this when i got my supra, had a RAC jack, i jacked the front driver side first, then the front pass side, then the back was worrying, as when i jacked up the stands started to move, but the supe wouldnt fall etc, then i did the rear driver side and finally the rear pass side which all 3 stands started to move a bit, but nothing would happen if you take it slowly. then when the car was on the 4 stands she wasnt going anywhere:) Quote Link to comment Share on other sites More sharing options...
robin Posted August 28, 2007 Share Posted August 28, 2007 I always give the car a couple of heavy shoves when its on the stands before I go under it. Just to make sure its stable. Quote Link to comment Share on other sites More sharing options...
Mike M Posted August 28, 2007 Share Posted August 28, 2007 After its down on the stands i always try and have the jack jacked up just to the point of contact somewhere in the area i'm working just as extra security........... Exactly the same as I do, would hate the sup to come down on me. Quote Link to comment Share on other sites More sharing options...
Pete Posted August 28, 2007 Share Posted August 28, 2007 This is how you do Jacking - Quote Link to comment Share on other sites More sharing options...
