HELP GUYS!!! PC Help - Failing to boot now
Sheefa
Had this spec for about 1 1/2 years now and it's been great, but now having some weird problems:
AMD X2 Dual Core 4600+ CPU
Gigabyte GA-K8NXP-9 Mobo
2 GB Geil Dual Channel 3200 Memory
Radeon X800 XL (Silent Core PCI-E) 256mb Graphics Card
Western Digital 36GB Hard Drive (10,000rpm)
Maxtor 200GB Hard Drive
Decent (can't remember make) 500watt PSU
2 X HP DVD Drives
Gigabyte WI-FI Card (came with motherboard)
So, recently my wireless has been playing havoc with the system and has caused it to freeze on numerous occasions so I removed it. However, also during this time my computer began to freeze after some length of time, watching a movie, browsing files etc.:search:
Now though the computer won't boot at all, or at least on 99% of occasions. Sometimes, and I mean rarely, it will load up the OS but otherwise the screen is BLANK - no DOS prompt, Boot Menu etc.:(
The memory is fine as it's brand new and I bought it to replace some G-skill stuff I had in there - problem existed before this anyway. I've also tried disconnecting the OS Hard Drive to see if I can just get to the Boot Up Menu, but no luck.
There's no POST beeps at all, but I can hear the Mobo trying to boot the drives twice, before giving up. As I said, the screen is completely BLANK, but sometimes will load up the Boot Menu. Wi-Fi card has been removed. I've run Registry Mechanic, Ad-Aware, Spyware Doctor and Diskeeper when I have managed to get in and all is well there.
What could it be??? I *think* it may be my Graphics Card on the way out, but any other good tests I can do to make sure guys please?
I'm hoping the CPU is ok!! I don't mind if I have to replace the Mobo as it isn't brilliant to be honest.
Hope you can help.:)
Cheers,
Greg
Many moons ago I had a similar problem that turned out to be the bios battery was flat. It was replaced and all was well.
I'm a bit crap on computers so I don't know if more modern PC's are likely to have the same problem.
Oooh, good point, would of never thought of that! Worth a shot I suppose - thanks. ;)
Guest gzaerojon
No! But if I take the BIOS battery out the Mobo won't start will it?
just to test the battery then pop it back in ;)
then i would go into the bios and check everything is as it should be
I think that even flat BIOS battery shouldn't cause blank screen, just all BIOS settings would reset. I would rather check CPU fan and graphic card fan at start. If computer keeps black screen or reseting himself, it is usually overheated CPU. If it is freezing and keep frozen windows screen or game/movie etc. it is graphic card (usually).
:yeahthat: is a good place to start.
I had the same problem on my daughters PC. It would only run if she took the side panel off and pointed a desk fan in there.
I took the heatsink off the CPU and brushed out all the dust and it's been fine ever since.
Usually during POST a graphic card failure would report an audible error code though wouldn't it?
either way no POST screen is pretty fundmental so would suggest mobo, cpu, or PSU to me
HTH
Mike
Ah yes, forgot about PSU - check power Supply obviously too! Clean it at start :)
  • 3 weeks later...
Take the graphics card out and boot up, you should hear "beeeeeeeeeeep beep beep beep" (thats the usual graphics post error).
If you dont get that (or any beeping), it aint your graphics card.
A flat CMOS battery shouldnt stop it from booting, but they are cheap should you want to try that.
Also, try booting up with just 1 RAM module in, if you get the same problem, replace the RAM module with another and try again. Just because you got new memory, doesnt mean its OK :)
Usually with problems like this I start the PC with the bare minimum installed.
Remove the cables & power to the HDD's, CD/DVD's, remove any unnecessary PCI cards and hardware, leaving purely the mobo, gfx card, CPU/Fan, and 1 stick of RAM.
This way you can eliminate all of that hardware straight away - and leaves you with less to look at.
Again I can't see a mobo battery causing the issues, but it's cheap to swap!
Right, done it.
Unplugged all HDs, CD/DVD Drives, 1 stick of old working RAM and took out graphics card. No beep/error signals made and of course it didn't boot to post.
I'm sure all Mobos have an LED that lights green when they're working correct? I think mine did, but nothing lights up anymore.
Must be dead Mobo or hopefully just the battery, I suppose it could stil be the CPU too, but PSU seems to be powering up just fine.
Greg
