mr keef Posted August 27, 2007 Share Posted August 27, 2007 Hey everyone..Does anyone know if you can change the stiffness settings on the HKS Hypermax suspension?and if so how,I have the HKS on my car and the rear seems very bouncy,fronts seem fine,i'v already had the hight adjusted,but was hoping there is a stiffness setting. Quote Link to comment Share on other sites More sharing options...
jazz1 Posted August 27, 2007 Share Posted August 27, 2007 well i have the latest set and the setting is ontop of the suspension you must have a long key to adjust it? Quote Link to comment Share on other sites More sharing options...
mr keef Posted August 27, 2007 Author Share Posted August 27, 2007 aghh jazz i didnt get any keys with the car:( Quote Link to comment Share on other sites More sharing options...
jazz1 Posted August 27, 2007 Share Posted August 27, 2007 http://www.mkivsupra.net/vbb/showthread.php?t=110381 look at the 9th picture you can see there is a thing in the middle of the suspension that where you have to adjust the stiffness maybe nic can source you the key il check it 2moro it be be shaped as an alan-key Quote Link to comment Share on other sites More sharing options...
mr keef Posted August 27, 2007 Author Share Posted August 27, 2007 nice one Jazz so basically you would loosen the big nut and go clockwise on the adjuster,then lock the nut up?or can it be done with the nut tight? Quote Link to comment Share on other sites More sharing options...
Hermit Posted August 27, 2007 Share Posted August 27, 2007 My guess (if they work like Teins) is leave the big nut alone. On Teins, you'd turn the adjuster fully clockwise to the hardest setting and then count clicks anticlockwise so you know where you are. I bet it's pretty similar Quote Link to comment Share on other sites More sharing options...
Nic Posted August 27, 2007 Share Posted August 27, 2007 Yes just use an allen key in the top to adjust. Clockwise hardens the damping, anti-clockwise softens. Wind both sides fully one way then dial out the same each side. Quote Link to comment Share on other sites More sharing options...
mr keef Posted August 27, 2007 Author Share Posted August 27, 2007 Cheers lads i shall give it a go:) Quote Link to comment Share on other sites More sharing options...
