green_dragon Posted November 14, 2004 Share Posted November 14, 2004 When the ignition is on, should the engine, and oil lights - on the r/h/s of steering wheel illuminate along with all the others?? Cos mine dont:( Chris Link to comment Share on other sites More sharing options...
supra dan Posted November 14, 2004 Share Posted November 14, 2004 yes they should, mine dont work sometimes either. must be a bad connection Link to comment Share on other sites More sharing options...
green_dragon Posted November 14, 2004 Author Share Posted November 14, 2004 Mine have never worked in the last 10 months of ownership:( What would cause this and how can I make them work? The plug seems ok as it has been off plenty of times in the past. Better start checking fuses then. Chris Link to comment Share on other sites More sharing options...
Matt Harwood Posted November 14, 2004 Share Posted November 14, 2004 It's a common fault. The pins inside the cluster need re-soldering. They're only hairline cracks, but it's enough to make them stop working. Link to comment Share on other sites More sharing options...
green_dragon Posted November 14, 2004 Author Share Posted November 14, 2004 Thanks for the info guys, I was starting to think it had been sabotaged to hide an engine fault or something. Paranoid much? Chris Link to comment Share on other sites More sharing options...
absz Posted November 14, 2004 Share Posted November 14, 2004 mine is wired into the immbolizer only come on when alarm is de-activated Link to comment Share on other sites More sharing options...
Matt Harwood Posted November 14, 2004 Share Posted November 14, 2004 The only lights that shouldn't illuminate when the ignition is immobilised are the Engine Management light, Alternator light, & Trac lights. All the others should light up. Link to comment Share on other sites More sharing options...
stt Posted November 14, 2004 Share Posted November 14, 2004 The company that used to service my car had devised a frame to put it in and resolder all the joints with,It took them about 10 minutes and thats about the only thing they were really good for! Just the solder joints have gone dry so if you know someone whos dead handy with the iron then im sure they could sort it for you Link to comment Share on other sites More sharing options...
