MarkR Posted August 24, 2007 Share Posted August 24, 2007 Anyone have a pic of the front decat pipe in a VVTI from underneath? I want to do this tomorrow so any hints would be good. Link to comment Share on other sites More sharing options...
MarkR Posted August 24, 2007 Author Share Posted August 24, 2007 Does the 1st cat have a sensor on it or anything that I'd have to refit to the decat pipe? Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 24, 2007 Share Posted August 24, 2007 No sensor, easy job *IF* the cat nuts on the turbo elbow casting come undone OK, and don't seize. If they do you'll wish you'd farmed the job out! I have more success undoing them when everything is stone cold, with lots of penetrant spray, but it's a lottery. Link to comment Share on other sites More sharing options...
MarkR Posted August 24, 2007 Author Share Posted August 24, 2007 Thanks Chris. I'm not driving it before doing the job (I picked up some exhaust assembly paste tonight so the exhaust wouldn't be hot tomorrow- far too sensible of me). I also bought some WD40 to hopefully loosen stuff up (wishful thinking probably). How long do the socket extensions have to be? Is it far in? What size are they? I guess I could figure this out myself. Just being lazy. Link to comment Share on other sites More sharing options...
Nic Posted August 25, 2007 Share Posted August 25, 2007 Not VVTi, but there are some pics here http://mkiv.com/techarticles/downpipe_pics/stock_cats/index.html Link to comment Share on other sites More sharing options...
JohnA Posted August 25, 2007 Share Posted August 25, 2007 WD40 is not that good as a penetrant. Try PlusGas Link to comment Share on other sites More sharing options...
MarkR Posted August 25, 2007 Author Share Posted August 25, 2007 Cheers... too late now. Gonna start in a few mins.. Link to comment Share on other sites More sharing options...
markrzs Posted August 25, 2007 Share Posted August 25, 2007 Good luck and let us know how you got on Link to comment Share on other sites More sharing options...
MarkR Posted August 25, 2007 Author Share Posted August 25, 2007 Thanks... just went downstairs and realised the axle stands are at the mother in laws house. This is gonna suck. I don't want to drive the car (heat from exhaust before working on it..ouch) but have no stands. Must find a replacement! Link to comment Share on other sites More sharing options...
RobSheffield Posted August 25, 2007 Share Posted August 25, 2007 This doesn't sound like its going well! Im doing a second decat, so we can compare notes and/or injuries after Link to comment Share on other sites More sharing options...
R Black Posted August 25, 2007 Share Posted August 25, 2007 So i take it you dont need gaskets to do this just paste right? P.S. goodluck you brave soul Link to comment Share on other sites More sharing options...
MarkR Posted August 25, 2007 Author Share Posted August 25, 2007 I have gaskets for the other pipes but apparently it's better to use the paste at the turbo end (Chris Wilson advised me to do this) The 2nd decat was easy, except I had to angle grind the bolts off cos they were stuck. Luckily I had spares Just called a mate to bring around some axle stands. Let the games commence I've also just put the std BOV back on to see if it makes any difference to my richness. Forgot to take a rag downstairs, was full of grease, and the phone rang. Don't you just hate that! Link to comment Share on other sites More sharing options...
MarkR Posted August 25, 2007 Author Share Posted August 25, 2007 Not VVTi, but there are some pics here http://mkiv.com/techarticles/downpipe_pics/stock_cats/index.html Thanks Nic... missed this earlier Link to comment Share on other sites More sharing options...
Sandy-m2 Posted August 25, 2007 Share Posted August 25, 2007 where did you get the gaskets from Rex?? Link to comment Share on other sites More sharing options...
MarkR Posted August 25, 2007 Author Share Posted August 25, 2007 From Chris Wilson Link to comment Share on other sites More sharing options...
Sandy-m2 Posted August 25, 2007 Share Posted August 25, 2007 Cool, will PM hime, cheers. (p.s. how much for your brake setup?) Link to comment Share on other sites More sharing options...
MarkR Posted August 25, 2007 Author Share Posted August 25, 2007 PM me. It's a mate who did it and it depends on if you supply the parts etc. I gave him some stuff in exchange (carbon fibre genuine supra steering wheel etc) and some money and supplied the parts, so it worked out cheaper than the UK spec ones. Stops very well. Link to comment Share on other sites More sharing options...
MarkR Posted August 25, 2007 Author Share Posted August 25, 2007 Just finished the turbo timer...piece of cake... off to get axle stands Link to comment Share on other sites More sharing options...
MarkR Posted August 25, 2007 Author Share Posted August 25, 2007 Today didn't go as well as planned. Got the first bolt off, no hassle Got the second bolt loose, no probs, Couldn't move the third, and snapped my universal joint on my socket set in the process. Figured I'd go back to bolt no 2 and then see if I could loosen the cat up a bit with only one bolt on it, and hopefully get no 3 off in the process. Only one problem! Bolt 2 was coming off fine, until halfway when the stud decided it wanted to come out too, so i put everything back on and am going to get someone to do it for me. I don't want to risk breaking off the stud or locking it up somehow. Nightmare. Who'd have thought 3 little nuts were so much hassle. Link to comment Share on other sites More sharing options...
Sandy-m2 Posted August 25, 2007 Share Posted August 25, 2007 doh! thinking this might not be a DIY job now. Link to comment Share on other sites More sharing options...
JohnA Posted August 25, 2007 Share Posted August 25, 2007 These studs snapping off: not exactly unheard of! Drill it out and fit a new one. When I needed to do mine I decided to have it done on a lift, as drilling snapped studs laying on my back stopped being fun years ago. Link to comment Share on other sites More sharing options...
MarkR Posted August 25, 2007 Author Share Posted August 25, 2007 Not the easiest lying on your back in the street. Will attempt to get it done tomorrow.. Will let you know how I get on. Link to comment Share on other sites More sharing options...
MarkR Posted August 25, 2007 Author Share Posted August 25, 2007 These studs snapping off: not exactly unheard of! Drill it out and fit a new one. When I needed to do mine I decided to have it done on a lift, as drilling snapped studs laying on my back stopped being fun years ago. My mate has ramps etc and all the tools, so I'm heading over there tomorrow Wish me luck! Link to comment Share on other sites More sharing options...
merckx Posted August 25, 2007 Share Posted August 25, 2007 If you do snap any studs, the turbo elbow came off very easily on my car. Link to comment Share on other sites More sharing options...
MarkR Posted August 25, 2007 Author Share Posted August 25, 2007 Thanks, that's a small relief, touch wood not snapped yet. My mate rebuilds supras and skylines for a living (and has a supra engined hilux complete with suspension, abs, ecu, dash etc all done by him ) so he's going to have a look for me. Hopefully it'll be okay. Link to comment Share on other sites More sharing options...
