"Free Air"
michael
What happened?
Why is that when you visit a garage forecourt these days you either have to pay for air (and I don't mind if it's a nominal amount) or you find the machine isn't working.
Should all garages have a duty to provide this service to the public for safety reasons?
My car felt a little odd on a trip out the other day, this sometimes means I'm a couple of psi out somewhere so I pulled in to check pressures - air line out of order.
I went to the next garage, the same.
The next one didn't have an air line so I carried on to one that only took 20p pieces, the chap on the till couldn't / wouldn't give me change unless I bought something that allowed him to open his till.
The next one was 50p for 5 minutes use... who needs 5 minutes of air?
Ultimately I ended up at a supermarket garage, free air, working water - and 4 tyres that were already at the right pressure, damn you odd road surface! Damn you!
So... "free air" - should it go back to being free? Should all garages have a duty to provide and should all machines have to be checked for accuracy on a regular basis? Or should we all just invest in a compressor at home?
NB: Elements of this post have added drama, the reality is that I have a pressure gauge in the car along with a foot pump so it was never going to be a disaster :)
You carry a footpump in your car? Do you also bulk buy screenwash?Think that deserves another infraction.
Me I got mini air compressor at home along with accurate digital pressure gauge don't trust pump gauges at forecourts as they get abused a lot / or just take your own pressure gauge to double check, never rely on there gauge pressures.
Is it unusual to have a footpump? I think it harks back to when I did trackdays and was constantly messing with pressures. These days it just sits in the rear footwell tucked under the passenger seat just in case...
I do buy screenwash in bulk :blink:
I wasn't aware it was a punishable offence, bugger.
I was very lucky a couple of weeks ago, where I felt the tyre go down just as I was about 50 yards from a Texaco station.
Luckily the machine worked and it only cost 20p. Pumped up the tyre and it's been ok ever since! Weird....:blink:
Granted though Michael, the majority are not working!! Might start my own compressor repair business as the world seems full of broken ones!!
H.
the ones round me are all 50p for 5 mins.
but you need to put in a quid as it takes for ever,only pumps air for a few seconds then builds up again before doing another pump.
i remember the old style ones where you put on the nozle and pressed the button and it went forever or untill ya tyre blew up
The free air ones round here usually leak and are crap.
The ones I pay a measly 20p for work properly.
My hatred of these things isn't the charge, it's the fact the ONLY take 20p and I never have 20ps in my pocket when I want to use one!
Last time I stopped at a garage in the middle of nowhere, I asked the guy behind the counter if they had an airline he said 'piss off, we don't even have a bus station'
Seriously though, they are a pain - you never have 20p when you need one and you can never be sure how accurate they are. Much better to have a decent gauge & compressor @ home and always check regularly/before long trips.
I had a cheap foot pump - the cylinder burst when I stepped on it too hard once. Made quite a bang, I can tell you.
Now I have a cheap compressor from Halfords. Never used a forecourt since.
It doesn't matter whether the pressure gauge is slightly wrong, because when you always use the same gauge, it is consistently wrong.
I bought a halfords compressor, it was about 15 quid and has lasted nearly 5 years so far, very accurate and very quickly gets the tyre to the pressure I set beforehand.
I had split rims once that used to lead, I set the pressure, went inside and finished my tea, came out and it was done. Cracking piece of kit (which neatly fits into one of the supra pre-cut areas of the boot).
Bargain.
Bargain.
Amazingly, exactly that for me as well. Type, cost, timespan, and reason :blink:
-Ian
-Ian
I bought one a couple of years ago - it worked once and never again. I concluded that it was total crap, and wouldn't waste my money again.
You two have convinced me that I was just unlucky, so I guess I'll pick another one up over the weekend.
I've also had one of those Michelin compressors for the last few years. Had to - all the garage ones were foobar'd.
Why is it the only air machines that work are the supermarket ones?
I thought Shell, BP etc were supposed to be big responsible companies. How come they don't keep better tabs on their forecourts?
