Guest Vangsoe Posted August 24, 2007 Share Posted August 24, 2007 Hi Guys, Anyone know where the fuel pump relay is sitting on a 1995 TT Euro spec ? A photo would be absolutely great. Tks again Niels from Denmark Link to comment Share on other sites More sharing options...
SimonB Posted August 24, 2007 Share Posted August 24, 2007 Hi Guys, Anyone know where the fuel pump relay is sitting on a 1995 TT Euro spec ? A photo would be absolutely great. Tks again Niels from Denmark There isn't one as such. There is a fuel pump ECU which is in the boot in the left hand wheel arch area. The power gets to that via the main EFI relay, which also switches the fuel injectors, ignitors etc. That one is in the main fuse box. Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 24, 2007 Share Posted August 24, 2007 Still struggling Niels? Have you got wiring diagrams? Link to comment Share on other sites More sharing options...
Guest Vangsoe Posted August 27, 2007 Share Posted August 27, 2007 Hi Chris, Yes i am...checked the crank position sensor as we spoke about - nothing wrong here. Also checked all the wiring - no probs. Checked the cam pos sensor as well - all OK - so now i am consentrating on the fuel pump relay / or ECU as mentioned by SimonB - No - unfortunately i have not got a wiring diagram so its been al voltage / resistance check till now...damn thing drives me nuts :-) Tks Niels Link to comment Share on other sites More sharing options...
Guest Vangsoe Posted August 27, 2007 Share Posted August 27, 2007 Hi SimonB Any of this: Tks again Niels from Denmark Link to comment Share on other sites More sharing options...
Guest Vangsoe Posted August 28, 2007 Share Posted August 28, 2007 OK - found out the fp ecu is located in the trunk ( boot as you call it ) Tks Simon Niels Link to comment Share on other sites More sharing options...
Wez Posted August 28, 2007 Share Posted August 28, 2007 Circled in red from memory, the two 30amps are the EFI fuses and the two relays are also for EFI if my memory is correct. Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 28, 2007 Share Posted August 28, 2007 Niels, I have put some stuff on my ftp server that may be of help, ftp://ftp.chriswilson.tv/niels with the user name niels and I have PM'd you the password Link to comment Share on other sites More sharing options...
Guest Vangsoe Posted September 4, 2007 Share Posted September 4, 2007 Hi Chris, Thanks a lot mate...i fould the problem - it was the fp ecu in the trunk that was acting up. Did a constant 12V fp mod,and she is up and running now - finally - :-) Tks all Best regards from Denmark Niels Link to comment Share on other sites More sharing options...
Wez Posted September 4, 2007 Share Posted September 4, 2007 Hi Chris, Thanks a lot mate...i fould the problem - it was the fp ecu in the trunk that was acting up. Did a constant 12V fp mod,and she is up and running now - finally - :-) Tks all Best regards from Denmark Niels How have you done the mod as it can be a fire hazzard if you crash. Turn your ignition on without starting the engine and the fuel pump should only prime and then stop, if it continues to run you would still have fuel flow in the event of a nasty accident, not a good idea. Link to comment Share on other sites More sharing options...
