Oil Level Sensor
charlieboo
The plug comes off the main loom the wire goes back to the indicator light on the right hand light pod, right of the speedo/rev dials.
Looking at the engine oil system diagram, the "oil level sensor" appears to be a similar sensor to the oil pressure sensor. The level sensor is fitted in the oil system between the sump pick-up and the oil pump and the oil pressure sensor comes off the oil gallery between the pump and the oil filter.
On this basis, it does not appear to be a genuine "level sensor" indicating oil level in the sump.
rgds
Georigg
rgds
Georigg
It is a true, float type level sensor. I wouldn't trust it though, and consider it a waste of time, you can't beat the old dipstick.
I found it very useful when my front main seal went, if i hadn't spotted the level light, the next thing i would have seen would have been the low oil pressure light, and then it would have been to late:(
So now i have a super bright LED wired into the level sensor;)
Thanks for replies. I have refurbed my loom (off the car) and when refitting it, I lost said connector. Turned out I had threaded it up through the intake runners towards the intake manifold by mistake. Found it after a few hours of head scratching. All sorted now.
