Wipeout Posted November 13, 2004 Share Posted November 13, 2004 I have removed the standard trim and in the process have damaged some of the existing plastic screw in things fitted to the car, so have pulled them out. Can these be bought? If so where? And part numbers if known. Cheers. Quote Link to comment Share on other sites More sharing options...
dude Posted November 13, 2004 Share Posted November 13, 2004 Try toyota , if you dont get anywhere phone me and ill get you a part number Dude:flame Dev Quote Link to comment Share on other sites More sharing options...
Wipeout Posted November 13, 2004 Author Share Posted November 13, 2004 Cheers dude. Quote Link to comment Share on other sites More sharing options...
Wipeout Posted November 14, 2004 Author Share Posted November 14, 2004 One more thing. The drivers side skirt (vent area) seems to be fixed using a threaded type of fixing and the passenger side is those push in white plastic clips, Both old vents used the plastic push in clips. What is the correct way to fix the threaded type? Quote Link to comment Share on other sites More sharing options...
Wipeout Posted November 15, 2004 Author Share Posted November 15, 2004 FAO body kit fitter type people See Pics Driver’s side: some sort of threaded thing. Passenger side: standard push in clips. What came off the car: standard push in clips. How does the drivers side secure to the car? Drivers side Quote Link to comment Share on other sites More sharing options...
Wipeout Posted November 15, 2004 Author Share Posted November 15, 2004 Passenger side Quote Link to comment Share on other sites More sharing options...
Wipeout Posted November 15, 2004 Author Share Posted November 15, 2004 Both together Quote Link to comment Share on other sites More sharing options...
Wipeout Posted November 17, 2004 Author Share Posted November 17, 2004 ^^^^Anyone^^^^ Quote Link to comment Share on other sites More sharing options...
Wipeout Posted November 18, 2004 Author Share Posted November 18, 2004 Last one...........I hope. Anyone got some of the clips in passenger side pic they do not require, or some old damaged trim/skirts they can be pinched from, or some part numers as local Toyota man keeps getting things wrong!!!!!! Quote Link to comment Share on other sites More sharing options...
lovatt Posted November 18, 2004 Share Posted November 18, 2004 after you called me i have had a look but i cant find a part number on these mate i may have some in my bitsnbobs box tho, ill take a look Quote Link to comment Share on other sites More sharing options...
Elliot Posted November 18, 2004 Share Posted November 18, 2004 Alright Chris I saw you a couple of days ago as I was going across the roundabout by the speed camera, you was coming around the roundabout to the Castle in the Air I guess. I put the hazards on put wasn't sure if you'd seen me! Anyway...Have you tried Silverlake scrapyard? There's 3 Supras up there. Most of the best bits are gone, I can't remember if they had any kits on them, but it might be worth a look as it's only 10 minutes from Fareham Quote Link to comment Share on other sites More sharing options...
Wipeout Posted November 18, 2004 Author Share Posted November 18, 2004 Originally posted by lovatt after you called me i have had a look but i cant find a part number on these mate i may have some in my bitsnbobs box tho, ill take a look Liam, is the part number for the other inserts on the system? It is a captive nylon square insert that is along both sides under the car, about 8 on each side, the stock trim secures to it with a 10mm self tap screw. Thanks. Quote Link to comment Share on other sites More sharing options...
Wipeout Posted November 18, 2004 Author Share Posted November 18, 2004 Originally posted by Elliot Alright Chris I saw you a couple of days ago as I was going across the roundabout by the speed camera, you was coming around the roundabout to the Castle in the Air I guess. I put the hazards on put wasn't sure if you'd seen me! Anyway...Have you tried Silverlake scrapyard? There's 3 Supras up there. Most of the best bits are gone, I can't remember if they had any kits on them, but it might be worth a look as it's only 10 minutes from Fareham Nope, didn't see you that time. Might go up there on the weekend to have a look. Cheers. Quote Link to comment Share on other sites More sharing options...
Pete Posted November 20, 2004 Share Posted November 20, 2004 It is a captive nylon square insert that is along both sides under the car, about 8 on each side, I've got some OEM skirts to fit soon too. I've never had skirts on before so I'm guess I'll need some of these? Quote Link to comment Share on other sites More sharing options...
Wipeout Posted November 21, 2004 Author Share Posted November 21, 2004 It might be handy to have a few. All the drivers side inserts were fine but the passenger side ones all spun when trying to undo them. They are £1.70 each from Toyota. They could not get them in before the weekend so i had to go to a local bdy shop to get some. Quote Link to comment Share on other sites More sharing options...
Pete Posted November 21, 2004 Share Posted November 21, 2004 So they're not a bespoke Toyota thing then? Quote Link to comment Share on other sites More sharing options...
Wipeout Posted November 21, 2004 Author Share Posted November 21, 2004 They are, but luckily the body shop had some i could have. Quote Link to comment Share on other sites More sharing options...
Pete Posted November 21, 2004 Share Posted November 21, 2004 Oh. bugger. Don't suppose you have the part number then? Quote Link to comment Share on other sites More sharing options...
Wipeout Posted November 21, 2004 Author Share Posted November 21, 2004 I will get it on Tuesday for you, it's at work. Quote Link to comment Share on other sites More sharing options...
Pete Posted November 21, 2004 Share Posted November 21, 2004 Thanks mate Quote Link to comment Share on other sites More sharing options...
Wipeout Posted November 23, 2004 Author Share Posted November 23, 2004 Part number is T53145-16010 Quote Link to comment Share on other sites More sharing options...
Pete Posted November 23, 2004 Share Posted November 23, 2004 Marvelous - Thanks v.much! Quote Link to comment Share on other sites More sharing options...
