AndyG Posted November 13, 2004 Share Posted November 13, 2004 Hey Guys My clutch has developed a click when I put my foot down on it, at about 50% of the way to the floor there is an audible (and can feel it slightly with my foot) click. Gear changes havent been affected, no difference in smoothness/etc - and happens if I'm in gear or not. I can replicate stationary with the engine off, in neutral. It doesnt click if I press down ever so slowly through full travel (not good for the legs!), and never clicks on the way back up. Always clicks at the same point, and is audible outside the car. Any ideas? N/A manual. I'll be having a look in the daylight tomorrow. Link to comment Share on other sites More sharing options...
absz Posted November 13, 2004 Share Posted November 13, 2004 if its only doing it in a certain place then it sounds like the return spring on ur pedal? try spraying some wd40 on it or check to see if its not broken:innocent: Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted November 13, 2004 Share Posted November 13, 2004 do the supras have a self ajuster on the pedal? My dads puma lost a tooth on the self adjuster and everytime pressed would jump down a tooth. Just a idea:) Link to comment Share on other sites More sharing options...
AndyG Posted November 13, 2004 Author Share Posted November 13, 2004 OK, cheers - I'll have a look in the morning when it's light. Link to comment Share on other sites More sharing options...
absz Posted November 13, 2004 Share Posted November 13, 2004 supra dont have self adjusters as the clutch system is hydraulic and not cable which you can adjust:innocent: Link to comment Share on other sites More sharing options...
