chainy Posted August 21, 2007 Share Posted August 21, 2007 Not very technical but i never had any replys in chat. Has anyone got any top tips on the best way to duct the airflow from a do luck replica bumper to the standard SMIC. Does it actually need anything even though all the standard ducting has been removed thanks. Quote Link to comment Share on other sites More sharing options...
colsoop Posted August 22, 2007 Share Posted August 22, 2007 There is a thread here with a bit of a how to that you could adopt to meet you own needs: http://www.mkivsupra.net/vbb/showthread.php?t=121357 Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 22, 2007 Share Posted August 22, 2007 If you don't duct it you will find it basically doesn't do much at all. You MUST make a proper sealed duct like the OE set up. Quote Link to comment Share on other sites More sharing options...
b_have Posted August 22, 2007 Share Posted August 22, 2007 If you don't duct it you will find it basically doesn't do much at all. You MUST make a proper sealed duct like the OE set up. Took me hours to make this from expanding foam. Sits between the nosecone and fmic. total seal. Quote Link to comment Share on other sites More sharing options...
dandan Posted August 22, 2007 Share Posted August 22, 2007 I spent a whole weekend ducting my fmic install. Bumper - intercooler and intercooler - rad. It's hard ducting with a stock bumper properly (mine is still unfinished in terms of cosmetics) and it's potentially easier with an aftermarket one (especially something like a Do-Luck). As far as ducting an aftermarket bumper to a side mount I guess you should be able to cobble something together using a combination of OEM ducting and some expanding foam. Whatever happens - do something and try to seal it completely. Quote Link to comment Share on other sites More sharing options...
