morgaine Posted June 2, 2002 Share Posted June 2, 2002 Hi guys Just fitted a stereo in my MkIV J-Spec, the stereo worked with no problems but the heaters have stopped working. I thought I must not have plugged them back in properly, but I've had the dash back off and they seem fine. There don't appear to be any blown fuses either. Is there something weird I should know about heaters and stereos? Also the built-in sub does not appear to work, is that going to be the small white connector by the stereo connectors that doesn't appear to go to anything at the moment? Cheers Morg Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted June 2, 2002 Share Posted June 2, 2002 Originally posted by morgaine Is there something weird I should know about heaters and stereos? Yep............... ..............Oh you want to know what it is ?? The A\C amplifier sits right on top of the stereo along with the antenna relay. Chances are if your control switches are plugged in OK, you have dislodged one of the two big (orange i think) plugs going into this A\C amplifier. I'm guessing everything worked before you fitted the stereo. Quote Link to comment Share on other sites More sharing options...
