Dirty fluid
Dave F
Had a problem a while back with my brake fluid turning dark a short while after changing it. The master cylinder went on me a few weeks back and I got hold of a replacement and had it fitted last week. I gave the guy 3 litres of new 5.1 fluid of which he used two litres but looking at the resevoir tonight it seems to have gone dark again. Should I be worried or do you think its just another flush is thats needed?
Thanks in advance
Dave
Bleeding brakes is not hard to do. If done properly all old fluid from the cylinder will have been flushed out as it is the only point at which new fluid is added. If you have had the master cylinder replaced, there would only be clean fluid introduced in the system. All your old fluid should have been flushed out. Something sounds very wrong.
