Dammit... The turbo dosent fit my manifold! What to do?
Reesen
HELL YA... Mde it fit :) But only just.. Can this be a problem later on??? Look at the 3 last pic´s
Just picked of my new turbo from the post office, and tried it with my manifold, and alll the other part´s. All the other parts fit´s like a glowe, but it just dosent fit the manifold :(
As you can see on these pictures it´s the turbine house that hit´s one of the pipe´s... What do I do?
Just make 15mm T4 flange and put in between or?? :search:
http://images.bilgalleri.dk/uploads_alb_large_wm/218540_l.jpg
http://images.bilgalleri.dk/uploads_alb_large_wm/218544_l.jpg
http://images.bilgalleri.dk/uploads_alb_large_wm/218549_l.jpg
Fitted
http://images.bilgalleri.dk/uploads_alb_large_wm/255867_l.jpg
http://images.bilgalleri.dk/uploads_alb_large_wm/255868_l.jpg
http://images.bilgalleri.dk/uploads_alb_large_wm/255869_l.jpg
  • Replies 50
Posted Images
If I twist it don´t you think I will get a nasty 90 turn on the pipework? And propperly get trouble fitting the pipework to the IC?
Pete I hope you're not installing this yourself?
Not all by my self.. Some of my friends have done it for them selvf on thir supras. But Ive only installed some supercgargers on some Golf´s and Polo´s, ao im preatty new in installing turbo´s. But don´t (hope not) think it will couse me that mutch trouble!!
I have a little expereince with this...
You will find that you need to rotate the compressor housing and it *should* clear. You might also need to remove the front support bar from the manifold as this will most likely block your oil drain.
Homer I have a little expereince with this...
Okay... i´ll trye that, if I cant get a small spacer plate to do the work (can make one my self at work):) Thank´s again Homer...
Wez Could you also post a pic of the wastegate port?
Here you go...
http://images.bilgalleri.dk/uploads_alb_large_wm/218752_l.jpg
http://images.bilgalleri.dk/uploads_alb_large_wm/218754_l.jpg
http://images.bilgalleri.dk/uploads_alb_large_wm/218756_l.jpg
I think he means a pic of the wastegate port from inside the manifold as I read a thread on here about a very inadequately built manifold where the hole for the wastegate was tiny and caused big problems with boost levels. I think it actually caused engine failure from what I remember.
About the spinning of the turbo housing it will be fine. I did it with mine because of the exact same problem. It is easier to adapt the intercooler piping if needed than to get sandwich plates etc made up. Also if you raise the height of the turbo you run the risk of your downpipe not clearing the chassis/bulkhead as it will be raised too. If you are getting a custom downpipe made then that obviously solves the problem though.
http://images.bilgalleri.dk/uploads_alb_large_wm/218819_l.jpg
http://images.bilgalleri.dk/uploads_alb_large_wm/218821_l.jpg
http://images.bilgalleri.dk/uploads_alb_large_wm/218823_l.jpg
gsportcars I think he means a pic of the wastegate port from inside the manifold as I read a thread on here about a very inadequately built manifold where the hole for the wastegate was tiny and caused big problems with boost levels. I think it actually caused engine failure from what I remember.
I already have my downpipe, ans after your (and taht´s an ofcouser after hearing it) info, I will spin the turbo housing tomorrow and see if that´s help!
Miami Quote:
Originally Posted by Reesen
It´s a XS power manifold
Noooooooooooooooooooooooooooooooooooooooooooooooooo poor supra
Haha... After what I´ve read there are diff menings about this one! Dosent Homer got one???
Guest Nicholas
From the pics we saw a while back of Homer's he seemed to have one of the few ok ones..
Miami Quote:
Mayme he still has the pictures so we can compere??
BTW.. This is a "low" budget project, so im cutting some cornes. I know some people might say " Then don´t do it ect.. But my goal is just to make it work, ofcouse with an okay resoult, do it my self, and have fun doing it! This is still better then buying a complete XS power kit, and the parts has only been aprox 400£ more expencive, I think my total cost right now is around 1300£ and "only" need the ECU!
