24 pot AMG brembo brake upgrade
paul mac
This is part 1 (the rears) nearly complete just have to finish the handbrake brackets for the other side, this is a full brake set up off an E55/CLS55/SL55 AMG, 4 pot 330mm dics on the rear 8 pot monoblock 360mm discs up front, when its finished i will post all the drawings/part numbers if anyone wants them
  • Replies 98
do the fronts fit straight on then?and when the rears are on is there enough clearence on the wheel;)
no the fronts will need a bracket as well but thankfully not as complex as the rears, there is loads of clearance for the rears my wheels are 18"s, its the fronts that are tight
:thumbs:
Great work Paul!nice to see someone trying something different that is worthwhile and works:cool:
fingers crossed it all works mate its only been round the block once with the rears fitted, it is a bit of a worry with brakes you check check and double check everything but i allways feel a bit uneasy on a test drive after brake maintenance
keep us posted on the fitting paul and i might get a set of these next year they look fantastic buddy very good mod you have done
where did you get the brake kit from;)
i take it the caliper is of a compact design
these are pics of the fronts with a test on the car, TBH i was never worried about the fronts as the 2003 merc they came off runs 18"s, it was the b*****d handbrake that caused all the bother
the fronts look similar to mine off an rs6but i used 378mm discs
they are very similar calipers i think car manufacturers want theirs to look unique so brembo probably make a few tweaks here and there but essentially they are the same, did you have to make the bells up or did they go straight on ?
