without doubt the best supra build ever
supradibbs
  • Replies 140
Posted Images
  • 5 months later...
dump wheels
You might not like the style but they are very good quality and very freakin expensive!
I cant understand why he went stock for some parts then went crazy aftermarket for others, why stock turbos with all that bling? not blowing their trumpets or anything but I'd say the ENVY build is more impressive, hopefully more so when finished
Well considering he got new doors because his perfectly fine doors werent fine to him, i would have thought he would have gone for a set of wheels that look decent. i mean hes gone for large aftermarket jobs anyway so its not like hes gona take it around a track. too much money, not enough vision
His budget became tight through the build, as he was going to go single, but he will go single when funds allow later, thats what he states early on anyway, im still browsing.
Shame he did'nt use a V8 lump.
This is the spec:
"Under the car I used a rust protective mass called Terotex Wax (Brand:Teroson)
I don't now if you have that in the US.
For the interior I used a Sound dampening mass called Peak off and I think it's a Swedish brand.
A little spec. list whats on the car.
Engine:
Brand new complete 2JZ-GTE engine
Intake manifold with 80mm throttle body made by SMR
Greddy 4-row intercooler
Greddy adjustable cam gears
Greddy oil filter relocation kit
Greddy BCC
HKS Hiper titanium exhaust
HKS complete intake pipe
HKS SSQV blow off
HKS EVC 5
Random Tech DP with high flow cat
MAP-ECU 1 with wiring harness
TRD Twin disc with new bearing and snap rings
TRD engine mounts
TRD transmission mount
AP engineering shifter bushings
C's short shifter
PWR radiator
AAP's dual fan kit
Samco radiator hose (lower)
PHR upper radiator pipe
Chassi:
Tein FLex coilovers
Tein EDFCs
Titan Motorsports adjustable sway bars
TRD strut tower bar modified to fit the Tein EDFC
Cusco strut tower bar rear (carbon)
R2 racing bushings with camber correction front and rear
Interior:
Sparco Milano II seats
Sparco steering wheel with Snap-off
MVP shift knob
TTC performance pedal set (ordered)
TTC performance alu. bezel set (ordered)
-98 style interior panels
DEFI boost and EGT gauges in the A-pillar pod
Exterior:
TRD widebody (MVP replica kit) with minor modifications painted in Quicksilver.
-98 style headlights
-98 style modified tail lights
Sparco fuel cap
Wheels:
CCW SP 500
Front:10x19"
Rear: 12x19"
Tires:
Yokohama Advan Sports
Front: 265/30-19
Rear: 315/25-19 (consider a change to 335)
Brakes:
OEM Supra brakes restord and painted in Toyota color 202 (black)
Cross drilled and slotted rotors front and rear
Goodridge stainless steel brake lines
Removed traction control
//andreas"
Absolute rubbish. Since when did you become the definitive authority on vision??!?
I've seen your idea of vision, and I don't like it. ;)
Those wheels are very nice IMO and I love the optimised OEM look of the car - absolutely great build :)
Cheers,
Brian.
Aaaaaaaaaaaargh I'm not a member :(
Why not join? cost nothing and then you will be able to search! Have to say though, I am a member but have no rights to do anything, post etc and every time I write to the administrators all I get is a message that my mail was not delivered due to exceeded mail in the mailbox - which I assume is theirs as I have no problems with mine!
haha that would be class.
Envy do new stock TT engines for £2350
Brand new block, pistons, rods, crank, head, cams, valves etc etc ?
I'll have a couple please for £2350 !!:D
Mr T is around the £5k mark for a full brand new engine.
Cheers,
Brian.
Totally agree :)
