Steviekid Posted August 17, 2007 Share Posted August 17, 2007 I had 2GB of RAM in my computer (one stick) and it came up in Windows as 2GB. I recently put another 2GB stick in (exactly the same one) but the total RAM only comes up as 3.25GB. Is this normal? Quote Link to comment Share on other sites More sharing options...
Fifty Posted August 17, 2007 Share Posted August 17, 2007 Normal If you are running 32-bit Windows, you must live with it. You will not ever see all 4GB of RAM you've paid for. - suprisingly a fact Rich Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted August 17, 2007 Share Posted August 17, 2007 It's true. Much of the address space is reserved for PAE which is a away of addressing more than 4GB. Possibly. I found the most cost effective option was just to install 3GB, and you see all of that! Quote Link to comment Share on other sites More sharing options...
Guest Geneb Posted August 17, 2007 Share Posted August 17, 2007 Normal If you are running 32-bit Windows, you must live with it. You will not ever see all 4GB of RAM you've paid for. - suprisingly a fact Rich Quote Link to comment Share on other sites More sharing options...
Steviekid Posted August 17, 2007 Author Share Posted August 17, 2007 Cheers guys, at least I haven't been sold dodgy RAM! Quote Link to comment Share on other sites More sharing options...
Steviekid Posted August 17, 2007 Author Share Posted August 17, 2007 It's true. Much of the address space is reserved for PAE which is a away of addressing more than 4GB. So what would happen if I put another 4GB in? Will it still sit at under 4 in total? Do you get all of it if you're running 64 bit Windows? Quote Link to comment Share on other sites More sharing options...
couv3z Posted August 17, 2007 Share Posted August 17, 2007 humm its all random access memory to me:blink: Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted August 17, 2007 Share Posted August 17, 2007 So what would happen if I put another 4GB in? Will it still sit at under 4 in total? Do you get all of it if you're running 64 bit Windows? I *think* 32bit XP supports up to 64gb with PAE, but most comsumer level motherboards wouldn't let you have more than 4gb. Been a while since I've looked at this though, the servers I deal with at work just cope with it no prob See here for some info on memory limits http://www.microsoft.com/whdc/system/platform/server/PAE/PAEmem.mspx Quote Link to comment Share on other sites More sharing options...
Big Mark Posted August 17, 2007 Share Posted August 17, 2007 So what would happen if I put another 4GB in? Will it still sit at under 4 in total? Yes. No matter how much more you put in, what you see now is as much as you will ever see. Do you get all of it if you're running 64 bit Windows? Yes Quote Link to comment Share on other sites More sharing options...
Steviekid Posted August 17, 2007 Author Share Posted August 17, 2007 I *think* 32bit XP supports up to 64gb with PAE, but most comsumer level motherboards wouldn't let you have more than 4gb. My motherboard has another two slots and can support up to 8GB(not that I'm planning to put that much in at the moment!). I'm running Windows Vista. Quote Link to comment Share on other sites More sharing options...
cheekymonkey Posted August 17, 2007 Share Posted August 17, 2007 My motherboard has another two slots and can support up to 8GB(not that I'm planning to put that much in at the moment!). I'm running Windows Vista. Oooh haven't times changed! http://support.microsoft.com/kb/929605 Looks like you're still out of luck unless you go 64 bit... Quote Link to comment Share on other sites More sharing options...
Steviekid Posted August 17, 2007 Author Share Posted August 17, 2007 Yes. No matter how much more you put in, what you see now is as much as you will ever see. Cheers, I've never realised there was a limit before! Do I need any special hardware to run 64 bit Vista? I've got an E6600, striker extreme motherboard and a crappy X600 graphics card at the moment (that will be the next thing to get changed). Quote Link to comment Share on other sites More sharing options...
