Annoying Belt Probs
SexySallySupra
Guest slow dog
wd40 eats rubber like most chemicals do. it maybe your belt or check your bottom crank pully some of them tear off and the early sign is a squek on start up
Guest slow dog
or you could just ring up toyota give your frame and engine number and get a proper one. please check the pully for play it sounds like it is nacked you cant be too carefull.:p
its an auxilliary drive belt that is for deffers not made by toyota themselves. The OEM one will not be made in any toyota factory. You don't mind using philips bulbs, garrets turbo's, blitz intercoolers so what difference is there to using an auxilliary belt? If you are that bothered buy two-if one snaps oh dear you have to fit another. If we were talking cam belts then yes I would understand to a degree. But I am betting that there are a lot of supra's about with non-OEM cambelts in them as well.
Mine squeaks too. Dunno if you mean a loud squeak that goes after a few revs, or a continuous squeal for a few minutes as it warms up?
IIRC from my thread on the same subject a lot of supras get it (the low volume one) and it's nothing to worry about.
Push down on the belt at the top where it runs alongside the engine block, if the wheel half way down (the only one with the belt wrapped around the inside [if that makes sense]) moves inwards then it is OK, also check that the mark on this wheel matches up with the 3 dashes on the block next to it (you may have to clean a bit of dirt off to see the marks.
If these two points are OK you're cool to keep the belt and put up with the noise - otherwise change it.
Guest slow dog
like i said mate part co are cheap and nasty i dont fancy being stuck in the middle of no where cause i fitted a cheap belt
that drives my water pump
The Gates belt will be as good if not better than the OEM one , you can also buy a special belt dressing to stop squeling etc , the bearings also wear in the tensiner pulley , so much so that i allways keep 1 or 2 in stock at all times , also the cam belt tensioner pulleys are also getting worn out , see it more and more now .
Dude:flame Dev
Originally posted by dude
The bearing is in the wheel dude , i just press in a new bearing and thats it sort of 'press and go' !!!;)
Dude:flame Dev
bollox i bought the wheel. oh well got it now :( and wasnt overly exspensive really
i take it,it was worth replacing seeing as its off anyway, it is now at 100km anything else i missed while i got the belts off, i am a NA
also could you answer me, while changing spark plugs i know throttle body etc... has to come off on NA, do i need to get a Gasket set or they reusable, i cant find no information on these at all! thanx dude :thumbs:
Guest slow dog
bsl in basingstoke do all sorts of bearings you can get one for the
tensioner which is alot stronger for 1 pound 50 and will last for ever
