SexySallySupra Posted November 11, 2004 Share Posted November 11, 2004 When first turning the car on in the morning I have a noise comming from one of the belts that spins round at the front of the engine, any ideas how I can put a stop to this sqeeky used conveyor belt sound Link to comment Share on other sites More sharing options...
Ian C Posted November 11, 2004 Share Posted November 11, 2004 Either get the belt replaced as it's stretched and worn, or squirt a bit of WD40 on it for a temporary measure -Ian Link to comment Share on other sites More sharing options...
Guest slow dog Posted November 11, 2004 Share Posted November 11, 2004 wd40 eats rubber like most chemicals do. it maybe your belt or check your bottom crank pully some of them tear off and the early sign is a squek on start up Link to comment Share on other sites More sharing options...
Digsy Posted November 11, 2004 Share Posted November 11, 2004 Yep, don't put WD40 anywhere near rubber. I "preserved" some brake parts with it recently and the seals changed size rather impressively. Luckily they were up for replacement anyway. Link to comment Share on other sites More sharing options...
Ian C Posted November 11, 2004 Share Posted November 11, 2004 Well, I did say get the belt changed And that WD40 was a temporary measure, not a be-all end-all fix to the problem. -Ian Link to comment Share on other sites More sharing options...
dangerous brain Posted November 11, 2004 Share Posted November 11, 2004 If ya do a search you will turn up a part number for a belt and also an argumentative thread about a partco style non toyota one that is vastly cheaper than the equivalent toyota belt. Link to comment Share on other sites More sharing options...
Guest slow dog Posted November 11, 2004 Share Posted November 11, 2004 or you could just ring up toyota give your frame and engine number and get a proper one. please check the pully for play it sounds like it is nacked you cant be too carefull. Link to comment Share on other sites More sharing options...
dangerous brain Posted November 11, 2004 Share Posted November 11, 2004 OEM toyota proper one circa £70 odd and bespoke good enough for a different car £11 now I am no rocket scientist but that makes sense to me. Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted November 11, 2004 Share Posted November 11, 2004 Yep i got the Part Co one, its sat with the oil filter, Cam belt, spark plugs ready for a full service! Link to comment Share on other sites More sharing options...
Guest slow dog Posted November 11, 2004 Share Posted November 11, 2004 toyota billion pound industry partco copy cat cheap and nasty Link to comment Share on other sites More sharing options...
dangerous brain Posted November 11, 2004 Share Posted November 11, 2004 its an auxilliary drive belt that is for deffers not made by toyota themselves. The OEM one will not be made in any toyota factory. You don't mind using philips bulbs, garrets turbo's, blitz intercoolers so what difference is there to using an auxilliary belt? If you are that bothered buy two-if one snaps oh dear you have to fit another. If we were talking cam belts then yes I would understand to a degree. But I am betting that there are a lot of supra's about with non-OEM cambelts in them as well. Link to comment Share on other sites More sharing options...
tbourner Posted November 11, 2004 Share Posted November 11, 2004 Mine squeaks too. Dunno if you mean a loud squeak that goes after a few revs, or a continuous squeal for a few minutes as it warms up? IIRC from my thread on the same subject a lot of supras get it (the low volume one) and it's nothing to worry about. Push down on the belt at the top where it runs alongside the engine block, if the wheel half way down (the only one with the belt wrapped around the inside [if that makes sense]) moves inwards then it is OK, also check that the mark on this wheel matches up with the 3 dashes on the block next to it (you may have to clean a bit of dirt off to see the marks. If these two points are OK you're cool to keep the belt and put up with the noise - otherwise change it. Link to comment Share on other sites More sharing options...
Guest slow dog Posted November 12, 2004 Share Posted November 12, 2004 Originally posted by dangerous brain its an auxilliary drive belt that is for deffers not made by toyota themselves. The OEM one will not be made in any toyota factory. You don't mind using philips bulbs, garrets turbo's, blitz intercoolers so what difference is there to using an auxilliary belt? If you are that bothered buy two-if one snaps oh dear you have to fit another. If we were talking cam belts then yes I would understand to a degree. But I am betting that there are a lot of supra's about with non-OEM cambelts in them as well. like i said mate part co are cheap and nasty i dont fancy being stuck in the middle of no where cause i fitted a cheap belt that drives my water pump Link to comment Share on other sites More sharing options...
LeeT Posted November 12, 2004 Share Posted November 12, 2004 you can get a Gates belt from halfrauds for £20. iirc they also make the belts for toyota so in theory you're getting the same part without the £50 toyota stamp Link to comment Share on other sites More sharing options...
Gordon F Posted November 12, 2004 Share Posted November 12, 2004 If it's squeaking it may not be tha belt at all. Could be coming from the power steering pump, where a little WD40 will help in the short term Link to comment Share on other sites More sharing options...
dude Posted November 12, 2004 Share Posted November 12, 2004 The Gates belt will be as good if not better than the OEM one , you can also buy a special belt dressing to stop squeling etc , the bearings also wear in the tensiner pulley , so much so that i allways keep 1 or 2 in stock at all times , also the cam belt tensioner pulleys are also getting worn out , see it more and more now . Dude:flame Dev Link to comment Share on other sites More sharing options...
Jake Posted November 12, 2004 Share Posted November 12, 2004 Originally posted by slow dog toyota billion pound industry partco copy cat cheap and nasty That's bollocks mate Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted November 12, 2004 Share Posted November 12, 2004 Dude, i got the new wheel part that goes on end of tensioner for belt, do i need to replace other bit, i got tensioner wheel part to replace as thought got it off, replace it I think the bit im on about attachs to engine and end of spring may attach to it or push against it, or i may be speaking bollox. Link to comment Share on other sites More sharing options...
dude Posted November 12, 2004 Share Posted November 12, 2004 The bearing is in the wheel dude , i just press in a new bearing and thats it sort of 'press and go' !!! Dude:flame Dev Link to comment Share on other sites More sharing options...
dude Posted November 12, 2004 Share Posted November 12, 2004 Originally posted by Jake That's bollocks mate Jake i really think you should start saying what you think on this BBS !!!! Dude:flame Dev Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted November 12, 2004 Share Posted November 12, 2004 Originally posted by dude The bearing is in the wheel dude , i just press in a new bearing and thats it sort of 'press and go' !!! Dude:flame Dev bollox i bought the wheel. oh well got it now and wasnt overly exspensive really i take it,it was worth replacing seeing as its off anyway, it is now at 100km anything else i missed while i got the belts off, i am a NA also could you answer me, while changing spark plugs i know throttle body etc... has to come off on NA, do i need to get a Gasket set or they reusable, i cant find no information on these at all! thanx dude Link to comment Share on other sites More sharing options...
dude Posted November 12, 2004 Share Posted November 12, 2004 Id change em dude , its not worth the agg not too Dude:flame Dev Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted November 12, 2004 Share Posted November 12, 2004 ok mate cheers, will go order some in from toyota tomorrow i guess:) Link to comment Share on other sites More sharing options...
Guest slow dog Posted November 13, 2004 Share Posted November 13, 2004 bsl in basingstoke do all sorts of bearings you can get one for the tensioner which is alot stronger for 1 pound 50 and will last for ever Link to comment Share on other sites More sharing options...
