tbourner Posted November 10, 2004 Share Posted November 10, 2004 OK, I 've never had to put in or top up anti-freeze in my cars before. So what do I need to put in? How much (%)? Should I drain and refill or just top up? Above all is it needed? I don't know what's in there at the moment. Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted November 10, 2004 Share Posted November 10, 2004 frost...water freezes...expands, pipes cant take it, crack then leak. so i suggest using it. The mixing of it is on the bottle different types require different concentrates. If u didnt do last top up id drain it. hope that helps Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted November 10, 2004 Share Posted November 10, 2004 Don't put anything other than the Toyota Red stuff (forlife?) in the soop. That's the only thing that I would ever put in mine. Ben.. Link to comment Share on other sites More sharing options...
merckx Posted November 10, 2004 Share Posted November 10, 2004 Lazarus posted this a couple of weeks ago. Quoting the manual:- Use a good brand of ethylene-glycol base coolant and mix it according to the manufacturer's directions. Using coolant which includes more than 50% ethylene-glycol (but not more than 70%) is recommended. NOTICE:- Do not use alcohol type coolant. The coolant should be mixed with demineralized water or distilled water. Link to comment Share on other sites More sharing options...
Guest slow dog Posted November 12, 2004 Share Posted November 12, 2004 do not use blue anti freeze as over long periods of time rots ali heads Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 12, 2004 Share Posted November 12, 2004 Originally posted by slow dog do not use blue anti freeze as over long periods of time rots ali heads Tosh, total tosh Link to comment Share on other sites More sharing options...
Aerotop Dave Posted November 12, 2004 Share Posted November 12, 2004 Originally posted by Soonto"HAS"soop Don't put anything other than the Toyota Red stuff (forlife?) in the soop. That's the only thing that I would ever put in mine. Ben.. Why not? My garage topped mine up the other day and I've no idea what they used. Link to comment Share on other sites More sharing options...
Guest slow dog Posted November 12, 2004 Share Posted November 12, 2004 Originally posted by Chris Wilson Tosh, total tosh tell volks wagon that Link to comment Share on other sites More sharing options...
mr keef Posted November 12, 2004 Share Posted November 12, 2004 Ethylene glycol doesnt rot ally heads,good old halfords anti freeze and summer coolant (corrosion inhibitor package) is wha i use,well i use in my 5 turbo dont know about my supe yet,might try the red stuff... Link to comment Share on other sites More sharing options...
tbourner Posted December 8, 2004 Author Share Posted December 8, 2004 What about just topping up? Some people have told me not to mix any of them, others say don't mix different colours, and a few have said it doesn't matter at all just top up with whatever you can get (as long as it's ethylene-glycol). Link to comment Share on other sites More sharing options...
mikeb Posted December 9, 2004 Share Posted December 9, 2004 Toyota 4Life coolant is used neat, not diluted like normal antifreeze. It's better than most other antifreeze and it lasts for ages. I left mine in for 12 years before I changed it, and it didn't look bad when I drained it (not that I would recommend going that long). Link to comment Share on other sites More sharing options...
Faith Adopter Posted December 9, 2004 Share Posted December 9, 2004 just had mine done at JPS and they used Red Valvoline pre diluted stuff Link to comment Share on other sites More sharing options...
