free nitrogen tyre inflation
uk-rich
Guest Diematrosen
Air is 80% nitrogen! Nitrogen is only marginally lighter than oxygen! It expands and contracts just like every other gas.Draw your own conclusions!
I believe but may be completely wrong that normal air in large commercial jet tyres would cause blowouts. I think the nitrogen is an inert gas and therefore doesn’t react or facilitate burning like a 20% oxygen mix might.
yes plus expansion of running about 230psi but the air in normal tyres can carry moisture at -50 temps this could cause havoc
Filling automotive and aircraft tires[2] due to its inertness and lack of moisture or oxidative qualities, as opposed to air, though this is not necessary for consumer automobiles.[3][4]
Nitrogen molecules are less likely to escape from the inside of a tire compared with the traditional air mixture used. Air consists mostly of nitrogen and oxygen. Nitrogen molecules have a larger effective diameter than oxygen molecules and therefore diffuse through porous substances more slowly.[5]
:blink:
Does it mean your tyre pressures will remain more constant then?
Is that the only key benefit?
