TRD LSD in j-spec auto casing
Gruggs
Hi Guys,
Used TRD LSD in J-spec auto casing. Will also include the carrier bearings when i receive them from Dusty.
I intended to fit this to the car but found mine already has a LSD and i'm planning on selling to fund a 911.
£400 plus p&p.
Cheers
G
  • 3 weeks later...
  • 1 month later...
its an auto unit , it wont fit a manual . different fitment
It will fit if you use the auto center section of the prop aswell, but be warned it lowers the gearing so the car tops out at 150ish on a manual but makes the car come on boost nice and fast thoughout the gears.:)
It will fit but it will break, i've done it once:innocent:
  • 2 months later...
Out of interest, what is involved in fitting it to a 96 auto TT?
Should be fine. Only thing is that when removing the current one you will bugger the carrier bearings. Been advised of this by a number of people including Chis Wilson.
Fortunately, the diff comes with all new bearings as well.
Cheers
G
  • 5 months later...
