upper dash warning lights knackered
supra steveo
  • 1 month later...
how ? theyve gone out again
You should read what's above. Unscrew odo panel, disconnect it, unscrew 3 (?) small screws over oil/engine managment lights. There is small plate under with few (now cracked) solders. Heat soldering iron and resolder... Or pop in to Wolves, I will do it for you no probs.
