supra steveo Posted August 10, 2007 Share Posted August 10, 2007 the lights that indicate low oil and the other on the right side upper dash arnt working anyone know any tricks to fix them? Quote Link to comment Share on other sites More sharing options...
supra dan Posted August 10, 2007 Share Posted August 10, 2007 they just need to be resoldered, its a common problem. its an easy job, if i can do it anyone can Quote Link to comment Share on other sites More sharing options...
Robert Posted August 10, 2007 Share Posted August 10, 2007 i sprayed mine with some contact cleaner and it sorted it. Quote Link to comment Share on other sites More sharing options...
edge Posted August 10, 2007 Share Posted August 10, 2007 If you want to pay for the postage each way i will resolder all the joints free of charge if you like? Quote Link to comment Share on other sites More sharing options...
supra steveo Posted August 10, 2007 Author Share Posted August 10, 2007 no its okay they work again Quote Link to comment Share on other sites More sharing options...
supra steveo Posted August 11, 2007 Author Share Posted August 11, 2007 its started again one of the light keeps flashing on and off until i bash it Quote Link to comment Share on other sites More sharing options...
Al Massey Posted August 11, 2007 Share Posted August 11, 2007 dont bash it then Quote Link to comment Share on other sites More sharing options...
Konrad Posted August 11, 2007 Share Posted August 11, 2007 Resolder it. Unscrew uppper part, disconnect it and take off part with lights. It is just 8 points you have to resolder and all will be fine again, it is not a big job... Quote Link to comment Share on other sites More sharing options...
d00gzy Posted September 27, 2007 Share Posted September 27, 2007 And was wondering how i go about getting to the circuit board! im fairly good when it comes to soldering but have no idea how to get there! Quote Link to comment Share on other sites More sharing options...
heckler Posted September 27, 2007 Share Posted September 27, 2007 its started again one of the light keeps flashing on and off until i bash it Re-solder them dude. Quote Link to comment Share on other sites More sharing options...
d00gzy Posted September 27, 2007 Share Posted September 27, 2007 Its ok, was wondering where the screws where to get that part of the dash off but got it, took out box, unscrewed it and now have them resoldered :-) Quote Link to comment Share on other sites More sharing options...
supra steveo Posted September 27, 2007 Author Share Posted September 27, 2007 Re-solder them dude. how ? theyve gone out again Quote Link to comment Share on other sites More sharing options...
Konrad Posted September 27, 2007 Share Posted September 27, 2007 how ? theyve gone out again You should read what's above. Unscrew odo panel, disconnect it, unscrew 3 (?) small screws over oil/engine managment lights. There is small plate under with few (now cracked) solders. Heat soldering iron and resolder... Or pop in to Wolves, I will do it for you no probs. Quote Link to comment Share on other sites More sharing options...
d00gzy Posted September 27, 2007 Share Posted September 27, 2007 above is correct, about 5 of the joints were dry and cracked, didnt even have to use solder, just touched em up and lights are working fine ( first time ive seen them go on since buyin the car lol :-) Still no warning about oil even tho my dipstick is dry! ? ! ? Quote Link to comment Share on other sites More sharing options...
supra steveo Posted September 27, 2007 Author Share Posted September 27, 2007 will have to give this a try then Quote Link to comment Share on other sites More sharing options...
