Austrian Supra Posted August 10, 2007 Share Posted August 10, 2007 I have my racelogic working in my Supra since about 3 years now, with Phils file and am happy with it. Last year I built the engine and installed a single turbo setup. Now I have about 800hp at 1,7 bar. The car runs strong and the RL seems to work generally, but there´s one thing that doesn´ t since the mods... The launch control. I cannot activate it. Normally I just push the green button and step on the gas….and it revs to where the revlimiter is set. Since last year, when I did the mods, I can push that button as often as I want….it doesn´t activate the LC . I haven`t changed any wires (as I use the plug and play AEM stand allone), and as I see the light flashing when checking the ABS sensors (fast and faster the fastzer I go), and also see it flashing when I check rpm signal (faster and faster the higher I rev), it seems all inputs are ok…..and as it reduces power when going WOT in first gear, I see it generally works… Any Idea? I also tried to set a new rev limit in pushing the button, then pushig (and holding it) and reving to where I want it to be……. As long as I hold the button the light flashes (ist that correct?). Then the revlimit should be set…… But when I try to activate the LC then …pushing the button…………..the revlimit doesn´t work It`s just like I did nothing………..it´s not activated…….. ANY IDEA? PLEASE help! I have a race on 1st Sept. and need the LC working by then…………. Thanks a lot in advance! Quote Link to comment Share on other sites More sharing options...
Austrian Supra Posted August 12, 2007 Author Share Posted August 12, 2007 Just found it out myself. Quote Link to comment Share on other sites More sharing options...
dandan Posted August 12, 2007 Share Posted August 12, 2007 What was wrong? Quote Link to comment Share on other sites More sharing options...
