Hurst Line Lock Kit
Terminator
Do you not plumb it after the ABS unit so that the line pressure is locked to the fronts no matter what the ABS pump tries to do?
That is what I was going to do. I have some instruction some where but for a Corvet. I think it is the same in principle.
  • 5 months later...
Still available.
This is fine with ABS. When not launching the unit is switched off so does not have any influence on ABS. When launching it by passes ABS. You put down the brake peddle to stop the car then press the line lock switch. When you release the peddlethe rears are free but the fronts remain locked on until you switch off the line lock
