Steve Posted November 6, 2004 Share Posted November 6, 2004 Can anybody see any problems with this pipe fitting on a Jap Spec TT http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=7931187269&ssPageName=STRK:MEWA:IT[/url] Cheers Link to comment Share on other sites More sharing options...
GeordieSteve Posted November 6, 2004 Share Posted November 6, 2004 If you don't buy this one I highly recommend Whifbitz all in one de-cats Link to comment Share on other sites More sharing options...
Steve Posted November 6, 2004 Author Share Posted November 6, 2004 Would this one fit. with the sensor hole onthe pipe. Link to comment Share on other sites More sharing options...
GeordieSteve Posted November 6, 2004 Share Posted November 6, 2004 Your talking to a complete numbty here but as far as I know the J spec ones don't have the sensor hole. You MAY be able to weld over it but I'd rather go for a propper J spec one that fits straight away.... which is what I'm about to do in about 10 minutes time! Link to comment Share on other sites More sharing options...
Steve Posted November 6, 2004 Author Share Posted November 6, 2004 Can anybody else confirm this. The J spec dont have the sensor on the exhaust. Cheers Geordiesteve Link to comment Share on other sites More sharing options...
keron Posted November 6, 2004 Share Posted November 6, 2004 i got told that these will only fit uk models as the flanges are different at the top? so they wont fit a jap car. Link to comment Share on other sites More sharing options...
merckx Posted November 6, 2004 Share Posted November 6, 2004 I've got a 97 J spec VVTI, there is no sensor in the cat pipe and none in the exhaust. I'm sure the UK spec car has one though. The flange fitted on the decat pipe has a flat face and 2 studs. All you have to do is make up a small steel plate to cover the flange and fasten it with 2 nuts on the studs - use a gasket to give it a good seal. You might even get these bits supplied. Link to comment Share on other sites More sharing options...
