Decat pipe
Steve
I've got a 97 J spec VVTI, there is no sensor in the cat pipe and none in the exhaust.
I'm sure the UK spec car has one though.
The flange fitted on the decat pipe has a flat face and 2 studs. All you have to do is make up a small steel plate to cover the flange and fasten it with 2 nuts on the studs - use a gasket to give it a good seal.:)
You might even get these bits supplied.:)
