MichaelH Posted August 8, 2007 Share Posted August 8, 2007 Since I bought my TT Supra I've had a steering wheel 'juddering' problem when cruising on the motorway. Its intermittent and have investigated several different possiblt causes. The current theory is that my wheels (which have been balanced) may be knackered and causing the problem. I need to either borrow some wheels for a run out on a dual carriageway or find some cheap wheels to buy (which are known not to have this problem) so that I can try and find if my current wheels are worth refurbing or not. Any help would be appreciated! Cheers, Michael (In Sheffield) Link to comment Share on other sites More sharing options...
DaveK Posted August 8, 2007 Share Posted August 8, 2007 I have some 17s you could have borrowed, but you're not really local enough. Link to comment Share on other sites More sharing options...
MichaelH Posted August 9, 2007 Author Share Posted August 9, 2007 Thanks Dave, hopefully someone a bit more local will have some I can borrow. Otherwise I might take you up on that! I'm sure petrol to Surrey and back would be cheaper (and less hassle) than buying some wheels and then trying to resell them... Link to comment Share on other sites More sharing options...
