RobEvans Posted August 7, 2007 Share Posted August 7, 2007 Iv just finished removing all the pipes ect from the turbos and all thats left are two turbos bolted to the manifold. Now theres nuts with like notches missing out of them, iv tried a 12mm socket and that fits around the but they're damn tight and I dont want to f*ck anything up... so whats the best way to remove these bad boys?! Link to comment Share on other sites More sharing options...
Marty Posted August 7, 2007 Share Posted August 7, 2007 You dont hang about do you Soak them in penetrating release, wd40, or something similar. They can be a barsteward to get off!! You may find that the stud will come out with the bolt on a few of them, but not to worry. Hope you have big muscles Do a search if your still stuck, its been covered a fair few times Link to comment Share on other sites More sharing options...
RobSheffield Posted August 7, 2007 Share Posted August 7, 2007 Plusgas is a useul lubricant/rust remover Link to comment Share on other sites More sharing options...
RobEvans Posted August 7, 2007 Author Share Posted August 7, 2007 thanks mate I'll soak em now... so will a 12mm be ok to use? Also can I just take the turbos out or do I have to remove them with the manifold, then split them? Iv already noticed two chipped blades on tubby no1 and ones bent. Thanks guys Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 7, 2007 Share Posted August 7, 2007 You should be able to either remove the whole manifold complete with the turbos, or separate the turbos from the manifold, but its a bit more of a pain, 12mm socket should be fine, and on the more hard to reach ones use a ring spanner. Link to comment Share on other sites More sharing options...
RobEvans Posted August 7, 2007 Author Share Posted August 7, 2007 Thanks Link to comment Share on other sites More sharing options...
RobEvans Posted August 7, 2007 Author Share Posted August 7, 2007 How the hell do you get the underneath ones free??! Link to comment Share on other sites More sharing options...
Marty Posted August 7, 2007 Share Posted August 7, 2007 With a big bag of patience and 2cans of luck. Plus a wobble bar or two on your ratchet spanner may help (attack it from underneath the car), or as i did, put the ring spanner on the nut, and smack it one with a bit of wood and a hammer, shocking the nut usually free's it, make sure the ring spanner is sitting perfect on the nut though, hold it on if you can, dont want to risk rounding the nut off. Link to comment Share on other sites More sharing options...
RobEvans Posted August 8, 2007 Author Share Posted August 8, 2007 Im realy struggling now with a couple of bits and bobs. Is there anyone in the north wets that can help me??? Please Link to comment Share on other sites More sharing options...
Robert Posted August 8, 2007 Share Posted August 8, 2007 lol you wouldnt be the first to find it difficult, that one lower bolt on the front turbo is a total B******* , no help i know but still Link to comment Share on other sites More sharing options...
Homer Posted August 8, 2007 Share Posted August 8, 2007 lol you wouldnt be the first to find it difficult, that one lower bolt on the front turbo is a total B******* , no help i know but still Oh yes, there's one thats an absolute b*tch to get to. I spent about 8 hours stripping the turbo's and other bits, but got stuck for 4 hours on that one bolt! A wobble bar and nearly 3 foot of extension bars were needed to undo it (even with plusgas soaking and heat). Link to comment Share on other sites More sharing options...
Robert Posted August 8, 2007 Share Posted August 8, 2007 4 hours? lmao i was there for 4 days. I used a blow torch, tried to freeze it, brute force, bolt cutters... gave up lol Link to comment Share on other sites More sharing options...
Homer Posted August 8, 2007 Share Posted August 8, 2007 4 hours? lmao i was there for 4 days. I used a blow torch, tried to freeze it, brute force, bolt cutters... gave up lol Did you try smacking it with a big hammer? It didn't help shift the bolt but I felt a lot better about it afterwards Link to comment Share on other sites More sharing options...
Robert Posted August 8, 2007 Share Posted August 8, 2007 i smacked it with everything i had rounded it in the end, well it could have been a brand new shape never heard of by the time i finished lol Link to comment Share on other sites More sharing options...
Wez Posted August 8, 2007 Share Posted August 8, 2007 Removing the stockers is a real pita but with patience you will do it. Just think, once they are off everything else is a piece of cake Link to comment Share on other sites More sharing options...
Sheefa Posted August 9, 2007 Share Posted August 9, 2007 Hence why I pay others to do the work for me, and hence my massive debt! Good luck mate. Link to comment Share on other sites More sharing options...
Bob Posted August 9, 2007 Share Posted August 9, 2007 I used a good quality combination ring spanner, and used a 3/4" ratchet through the standard spanner end. It meant that the angle could be changed to get to the bolts easy, and they came off in a jiffy Link to comment Share on other sites More sharing options...
RobEvans Posted August 9, 2007 Author Share Posted August 9, 2007 Just finished removing them now, what a BAST**D of a job! Just one rusty bolt can set you back so many hours! The turbos dont seem in to bad of a nick apart from two blades with chips, but I suppose I wont know if the seals gone or not though? I need to decide what I'm going to do next to Link to comment Share on other sites More sharing options...
Jake Posted August 9, 2007 Share Posted August 9, 2007 I've only ever taken the stockers off with the engine out of the car. It's bad enough then, God only knows how you do it in situ. I reckon it might actually be quicker to take the engine out though. It's so much easier to get at everything then. Link to comment Share on other sites More sharing options...
RobEvans Posted August 9, 2007 Author Share Posted August 9, 2007 We was thinking of that... but it was outside my house Link to comment Share on other sites More sharing options...
