Myles Posted May 29, 2002 Share Posted May 29, 2002 While trying to remove my damaged a/c pipe , I've come to a stop . I think I'll need to remove the front bumper/nose-cone to get access to the condensor(radiator type thingy), `cos it's the hard pipe that leads to the bottom of it that I need to replace . Any tips/help/suggestions on removing the bumper? I take it I'll need to remove the headlamps - and I can only see one bolt for them , how many bolt are used to afix the lamps? edit: its got the active spoiler to add to the complications Link to comment Share on other sites More sharing options...
rayg Posted May 29, 2002 Share Posted May 29, 2002 3 bolts for the headlights, don't know about the bumper:eek: Link to comment Share on other sites More sharing options...
Myles Posted May 29, 2002 Author Share Posted May 29, 2002 I can see the obvious one , nearest the bonnet catch , there's one near the foglamp end the bolts to a bracket on the wing (I think .... is the 3rd one underneath? Link to comment Share on other sites More sharing options...
rayg Posted May 29, 2002 Share Posted May 29, 2002 1 on the top and 2 down the side. You get to them from the top. Cheers for the paint reply but need a aerosol. Hoping Darby might know...same colour of car Link to comment Share on other sites More sharing options...
Don Huhnson Posted May 29, 2002 Share Posted May 29, 2002 When you're going to remove the front-bumper, you have to loosen 2 bolts (one on each side of the bumper), which you only can reach if you uncover/loose the plastic parts in the mud-guards. The other bolts to detect is quite simple. Good luck, Don Link to comment Share on other sites More sharing options...
ststarkie Posted May 30, 2002 Share Posted May 30, 2002 2 bolts on each wheel arch a couple under each light plastic screws top middle under rubber strip where bonnet touches radiator gap plastic screws top of hole and bottom of hole and finally around the edge underneath i think there were about 6 bolts i hope this helps u steve s Link to comment Share on other sites More sharing options...
Myles Posted May 30, 2002 Author Share Posted May 30, 2002 Thanks a million Guys:) Link to comment Share on other sites More sharing options...
Ian C Posted May 30, 2002 Share Posted May 30, 2002 Myles, Can you take digital piccies of this procedure as you do it? For others to use as reference in the future? -Ian Link to comment Share on other sites More sharing options...
Myles Posted May 30, 2002 Author Share Posted May 30, 2002 -problem:D My digital camera is Noahs arc spec , but it can make images o.k. I'll do it on the week starting 10 June ...if it's dry and if I can get it up (oooeer!) onto my little ramps Link to comment Share on other sites More sharing options...
