Help please?
Myles
While trying to remove my damaged a/c pipe , I've come to a stop . I think I'll need to remove the front bumper/nose-cone to get access to the condensor(radiator type thingy), `cos it's the hard pipe that leads to the bottom of it that I need to replace .
Any tips/help/suggestions on removing the bumper?
I take it I'll need to remove the headlamps - and I can only see one bolt for them , how many bolt are used to afix the lamps?
edit: its got the active spoiler to add to the complications
2 bolts on each wheel arch
a couple under each light
plastic screws top middle under rubber strip where bonnet touches
radiator gap plastic screws top of hole and bottom of hole
and finally around the edge underneath i think there were about 6 bolts
i hope this helps u
steve s
