wilkorangerover Posted August 6, 2007 Share Posted August 6, 2007 hi iam taking of my supra front bumper ready for front mount install... i have taking of 3 bolts from each side... 5 in the middle, and one either side inder the lights, but the bumper still seems solid...... can any body help????? Quote Link to comment Share on other sites More sharing options...
Rayman Posted August 6, 2007 Share Posted August 6, 2007 There is two more sets of bolts under the front wheel arches but towards the front bumper, there is a guide on here to explain it better. Quote Link to comment Share on other sites More sharing options...
Rayman Posted August 6, 2007 Share Posted August 6, 2007 http://www.mkivsupra.net/vbb/showthread.php?t=40235 here Quote Link to comment Share on other sites More sharing options...
Rayman Posted August 6, 2007 Share Posted August 6, 2007 These are the ones you havnt got at by the sounds of it! 5) The two hardest fasteners to actually get to are right in the corners of the bumper, a couple of inches inside the wheel arch liners. With just the front liners removed you will just be able to get onto them, but you might need someone to hold the upper wheel arch liner out of the way. Youl will also need to turn the wheels from lock to lock for extra access. If you are lucky, the studs will be identified with bright yellow plastic caps on the ends (which you do not need to take off). There are two more similar fastenings (making four in total) about 10 inches further forwards, but ther are much easier to get to through the light holes. Quote Link to comment Share on other sites More sharing options...
wilkorangerover Posted August 6, 2007 Author Share Posted August 6, 2007 wheres the guide? Quote Link to comment Share on other sites More sharing options...
wilkorangerover Posted August 6, 2007 Author Share Posted August 6, 2007 also is there all the plastic trays to remove underneath?? Quote Link to comment Share on other sites More sharing options...
Rayman Posted August 6, 2007 Share Posted August 6, 2007 http://www.mkivsupra.net/vbb/showthread.php?t=40235 here here:d Quote Link to comment Share on other sites More sharing options...
Rayman Posted August 6, 2007 Share Posted August 6, 2007 also is there all the plastic trays to remove underneath?? No not required to remove the undertray, although you ahve to undoe the fasterners that fasten to the undertray. The guide is v good, i did it off that guide, just follow it and take your time. Quote Link to comment Share on other sites More sharing options...
wilkorangerover Posted August 6, 2007 Author Share Posted August 6, 2007 everything is undone , but the two strips with the fastners are solid the fastners come down about a cm but dont dont all thw way out............ Quote Link to comment Share on other sites More sharing options...
zap Posted August 6, 2007 Share Posted August 6, 2007 Presume you mean the strips in the bumper mouth, these are expanding clips not fasteners, you need to be careful removing these as they tend to break, you should be able to gently lever the middle piece out then the rest comes. you can see the top ones better if remove the rubber strip that supports the bonnet. hope this is of some help. Quote Link to comment Share on other sites More sharing options...
