conversion kit for kms to mph & de-restrictor
SupraGirlie
Guest Nicholas
How can one converter be better than another, they either do the job or they don't surely?
Please don't ever change anything about your car if you think like that :( poor supra :(
Just like you would think one TV does the same job as another.
That's different though, I mean it either changes the KMS into miles or it doesn't? Is it to do with how accurate it is or something?! I'm quite happy to buy it, if I know it's worth it, that was all.
Guest Chumpalot
Go for the Thor one. Have heard nothing but good things about it :thumbs:
You don't want it to be like mine where the speedo goes mental and it starts affecting your PPS do you?
It just does, OK? :D
If the answer you seek is 'yes, they all do the job' then yes, they all do the job. Just like a TV, it either displays a picture and makes sounds or it doesnt, so no, its not different.
Seriosly thou the TRL (thor) one is more accurate, better build quality, will last longer (the amount of cheap ones that go bang is high) and more importantly is tried and tested many times over on here.
Shelling out £40 for a cheapo one, spending the next 4 hours installing it only to find a year later it goes pop probably is not your idea of fun?
I bought one off ebay for £40 when I didn't know any better and the speedo needle bounced around all over the place. Bought the TRL one and problem solved.
  • 2 weeks later...
