Elmo Posted August 5, 2007 Share Posted August 5, 2007 Has anyone bought these dials? If so, can they really be fitted without removing the needles? Cheers http://cgi.ebay.co.uk/TOYOTA-SUPRA-AUTO-MANNUAL-WHITE-DIALS_W0QQitemZ290144290115QQihZ019QQcategoryZ10428QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Quote Link to comment Share on other sites More sharing options...
Kieran Posted August 5, 2007 Share Posted August 5, 2007 Assuming they're the bendy ones, you just bend them over the needles, if you do need to take them off for whatever reason, there's plenty off threads showing how. Quote Link to comment Share on other sites More sharing options...
Elmo Posted August 5, 2007 Author Share Posted August 5, 2007 Assuming they're the bendy ones, you just bend them over the needles, if you do need to take them off for whatever reason, there's plenty off threads showing how. Might give them a go, look like good value! Quote Link to comment Share on other sites More sharing options...
Kieran Posted August 5, 2007 Share Posted August 5, 2007 They seem to crop up quite a lot, so I'm sure someone who has fitted them will come along eventually to give an idea of what they're like. Quote Link to comment Share on other sites More sharing options...
Elmo Posted August 5, 2007 Author Share Posted August 5, 2007 I'd be interested what people make of them, the images look excellent! Quote Link to comment Share on other sites More sharing options...
SIMON LC Posted August 5, 2007 Share Posted August 5, 2007 Yes they are a a piece of piss to fit and no needle removel necessary.I fitted some and they look the business.I would recommend. Quote Link to comment Share on other sites More sharing options...
mplavery Posted August 5, 2007 Share Posted August 5, 2007 i have fitted those dails, i done a write up with pics http://www.mkivsupra.net/vbb/showthread.php?t=106932 Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted August 6, 2007 Share Posted August 6, 2007 You dont need to remove the needles. If you buy from them elmo, you get some very good instructions with it in the box, i have just fitted mine, see here for pics mate: http://www.mkivsupra.net/vbb/showthread.php?t=120104 Quote Link to comment Share on other sites More sharing options...
Elmo Posted August 6, 2007 Author Share Posted August 6, 2007 i have fitted those dails, i done a write up with pics http://www.mkivsupra.net/vbb/showthread.php?t=106932 Good write up and nice pics, but you mentioned removing the needles? Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted August 6, 2007 Share Posted August 6, 2007 you 100% dont need to remove the needles, it took me 15 minutes from starting to take the dash out, to fitting it back in with the new dials. And they look amazing!!! Quote Link to comment Share on other sites More sharing options...
Elmo Posted August 6, 2007 Author Share Posted August 6, 2007 You dont need to remove the needles. If you buy from them elmo, you get some very good instructions with it in the box, i have just fitted mine, see here for pics mate: http://www.mkivsupra.net/vbb/showthread.php?t=120104 They are bright! do you need to wear shades when driving at night? Quote Link to comment Share on other sites More sharing options...
imi Posted August 6, 2007 Share Posted August 6, 2007 Has anyone bought these dials? If so, can they really be fitted without removing the needles? Cheers http://cgi.ebay.co.uk/TOYOTA-SUPRA-AUTO-MANNUAL-WHITE-DIALS_W0QQitemZ290144290115QQihZ019QQcategoryZ10428QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Nice AVATAR BTW.......couldnt resist Quote Link to comment Share on other sites More sharing options...
Elmo Posted August 6, 2007 Author Share Posted August 6, 2007 Nice AVATAR BTW.......couldnt resist Cheers mate Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted August 6, 2007 Share Posted August 6, 2007 they dont look that bright, its the samera what makes them look like that, however all the gauges and the dials are wired through the dimmer swithc, should you want to dim them. Those ones you posted up are the same as mine and you get a control box which also has a dimmer, and a button to stwitch between green and blue mate. ALSO where is your avatar from??? Quote Link to comment Share on other sites More sharing options...
Elmo Posted August 6, 2007 Author Share Posted August 6, 2007 they dont look that bright, its the samera what makes them look like that, however all the gauges and the dials are wired through the dimmer swithc, should you want to dim them. Those ones you posted up are the same as mine and you get a control box which also has a dimmer, and a button to stwitch between green and blue mate. ALSO where is your avatar from??? Cheers for that mate, they sound like a good deal. I just found the avatar while surfing the net one day, I thought I'm having that! Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted August 6, 2007 Share Posted August 6, 2007 Cheers for that mate, they sound like a good deal. I just found the avatar while surfing the net one day, I thought I'm having that! Good choice!!! i would have had it straight away aswell. (**goes off to search for one similar**) Quote Link to comment Share on other sites More sharing options...
Elmo Posted August 6, 2007 Author Share Posted August 6, 2007 Good choice!!! i would have had it straight away aswell. (**goes off to search for one similar**) Thats a nice pair Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted August 6, 2007 Share Posted August 6, 2007 :search:They were meant to move though Quote Link to comment Share on other sites More sharing options...
Elmo Posted August 6, 2007 Author Share Posted August 6, 2007 :search:They were meant to move though WOW!!! BATTLE OF THE BIG'UNS!!!! Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted August 6, 2007 Share Posted August 6, 2007 ;););) Quote Link to comment Share on other sites More sharing options...
Elmo Posted August 6, 2007 Author Share Posted August 6, 2007 I could sit here and watch them battle it our all day Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted August 6, 2007 Share Posted August 6, 2007 me too, can see nipples on mine, ner ner ner ner nerrrrrrrr. :d Quote Link to comment Share on other sites More sharing options...
Elmo Posted August 6, 2007 Author Share Posted August 6, 2007 me too, can see nipples on mine, ner ner ner ner nerrrrrrrr. :d mmmmmmm nipples Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted August 6, 2007 Share Posted August 6, 2007 Hahahaha Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted August 6, 2007 Share Posted August 6, 2007 this whole page is just full of boobs. Im going to follow you round the forum Elmo to spread our avatars everywhere :yahoo::yahoo::yahoo::yahoo::yahoo::yahoo::yahoo::yahoo::yahoo::yahoo: Quote Link to comment Share on other sites More sharing options...
