Trying to fit rear spats......
ChrissupraSZ
guys i have some standard toyota rear spats.
Ive taken my old plastic bits off. But, where the bottom screw goes in there seems to be some sort of bracket missing. i.e there is about a 2inch space between the bottom of the spat and the screw whole.
any ideas guys?
am i missing a bracket?
I took off my spat the other day, underneath it was held on by a massive lump of mastic.
There isn't a hole in the bottom of my spat or any other obvious way of fixing a bracket.
The spat was held on by the 3 screws on the wheelarch, the vertical and horizontal edges were secured using double sided tape.:)
any ideas guys?
There should be a metal bracket that it screws into.
I don't know why mine doesn't have a bracket.:(
I've just been looking at the spat, the screws and the double sided tape are more than sufficient to hold it in place.
You don't need a bracket.:)
Chris, Did you fit the skirts at the same time? Have you a pic of where it meets the sill....just under the door? I have skirts, spats and front lip ready to fit and also would like to know if you have to take all that black plastic off before you start?
thanks
Roy.
thanks
Roy.
You do :D
Dude:flame Dev
thanks
Roy.
yes mate.
the skirts are held on by a few screws and 10 mil bolts on the sill. they were a bit rusty but once they were loose i had no problems.
the rear spats are just held on by 3 screws and double sided tape(which they were previously held on by).
truthfully a very easy job.
im going to put a line of silicone on the upper sill of the skirts just to make them solid.
all the black plastic bits come off m8. They r all screws and bolts too.
really wasnt hard m8.
i would get someone to help you though. makes things alot easier when aligning the skirts.
any probs gis a pm m8.
yes mate.
Hmmmm the tape is designed for use only once. It will not have anywhere near the same adhesive properties second time round. The drag on them at high speed will be huge. I would fit new tape.
Try Brown Brothers.
