Wez Posted August 3, 2007 Share Posted August 3, 2007 Hey All, Just wondering what size jets people are using. I have the standard 0.5mm that was supplied with the kit. Is it worth going bigger? Quote Link to comment Share on other sites More sharing options...
Wez Posted August 3, 2007 Author Share Posted August 3, 2007 Here are the jet flow rates. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 3, 2007 Share Posted August 3, 2007 Quite easy to calculate: add all your injectors flow rate together and multiple it by 10% or 15% - look at the aquamist jet size/flow, that is it! Which is why i'm using 0.9mm jet. Quote Link to comment Share on other sites More sharing options...
Wez Posted August 3, 2007 Author Share Posted August 3, 2007 Hmmmm. 650cc x 6 = 3900 10% of 3900 = 390 How does this tell me what size jet I should be using, am i missing something? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 3, 2007 Share Posted August 3, 2007 Hmmmm. 650cc x 6 = 3900 10% of 3900 = 390 How does this tell me what size jet I should be using, am i missing something? Look up 390 ml sec on the flow chart;) Quote Link to comment Share on other sites More sharing options...
Wez Posted August 3, 2007 Author Share Posted August 3, 2007 Ahh ok, so I need a 1.3mm or there abouts Quote Link to comment Share on other sites More sharing options...
Wez Posted August 3, 2007 Author Share Posted August 3, 2007 I guess I could use two 0.7mm jets with a T piece. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 3, 2007 Share Posted August 3, 2007 .9 mm works fine for 90% of the Supras I fit the kits to. If you inject too much you'll kill power. Quote Link to comment Share on other sites More sharing options...
Wez Posted August 3, 2007 Author Share Posted August 3, 2007 Chris, what size jet did you install on mine? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 3, 2007 Share Posted August 3, 2007 Chris, what size jet did you install on mine? It should have a .9mm jet in it. Quote Link to comment Share on other sites More sharing options...
Wez Posted August 3, 2007 Author Share Posted August 3, 2007 OK cool. Quote Link to comment Share on other sites More sharing options...
Wez Posted August 6, 2007 Author Share Posted August 6, 2007 I checked my Jet this weekend and according to the aquamist site mine is 0.7mm as it has a red colour code, 0.9mm would be a white colour code. Would it be worth me upgraded this to two 0.6mm jets which would equal 1.2mm which is close to 350ml/sec on the chart. Quote Link to comment Share on other sites More sharing options...
dandan Posted August 6, 2007 Share Posted August 6, 2007 Where is your jet Wez? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 6, 2007 Share Posted August 6, 2007 I wouldn't go bigger than a .9 myself Wez. You don't need that much water as you are running a well matched turbo with a decent I/C, you only need maximum if overspeeding something like the stock ones. Quote Link to comment Share on other sites More sharing options...
Wez Posted August 6, 2007 Author Share Posted August 6, 2007 Just before the throttle plate. Quote Link to comment Share on other sites More sharing options...
Wez Posted August 6, 2007 Author Share Posted August 6, 2007 I wouldn't go bigger than a .9 myself Wez. You don't need that much water as you are running a well matched turbo with a decent I/C, you only need maximum if overspeeding something like the stock ones. OK cool, would it be a good idea for me to just replace my single 0.7mm jet with a 0.9mm jet, they are only 10 quid from aquamist. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted August 6, 2007 Share Posted August 6, 2007 I think thats what CW is trying to say Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted August 6, 2007 Share Posted August 6, 2007 OK cool, would it be a good idea for me to just replace my single 0.7mm jet with a 0.9mm jet, they are only 10 quid from aquamist. Of course it does depend on just what kit your using, as i run the 2C with high speed valve, which in effect is an injector, run by EMU then i go for the maximum size that could be needed for the fuelling, but if your running a pressure controlled kit then it will spray the full amount as soon as the switch point is reached. Quote Link to comment Share on other sites More sharing options...
Wez Posted August 6, 2007 Author Share Posted August 6, 2007 Mine does not come on till 1bar boost. Quote Link to comment Share on other sites More sharing options...
Wez Posted August 6, 2007 Author Share Posted August 6, 2007 I think thats what CW is trying to say Quote Link to comment Share on other sites More sharing options...
JohnA Posted August 6, 2007 Share Posted August 6, 2007 The max flow rate of the jet(s) also depends on the pump's capacity. The Aqumist pump can have it's flow capacity almost doubled if you use a cheap priming pump before (it hates sucking) I'd be inclined to go further than Chris and use nothing bigger than 0.8mm. (obviously it also depends on your max airflow!) In fact I only use 0.4, 0.5 and 0.6 Atomisation is better with the smaller jets, and on a good setup you don't want to have one cylinder receiving twice the water mist of another cylinder;) Quote Link to comment Share on other sites More sharing options...
