imi Posted February 21, 2008 Share Posted February 21, 2008 aha...didnt know that I could buy a HD box and use that with Sky+ Quote Link to comment Share on other sites More sharing options...
imi Posted February 21, 2008 Share Posted February 21, 2008 quick update those splitters dont work. if you have a communal dish you need to run another cable of the distrabution system in the loft space found the solution that I was looking for SPS1 Smart Priority LNB Switch http://www.satcure.co.uk/accs/page1b.htm thx to the world of the internet... Quote Link to comment Share on other sites More sharing options...
adam bell Posted February 21, 2008 Share Posted February 21, 2008 that switch should allready be in the loft where all the wires come in Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted February 21, 2008 Share Posted February 21, 2008 Thats not going to work is it? If its in use on one channel then the other won't work?? Quote Link to comment Share on other sites More sharing options...
adam bell Posted February 21, 2008 Share Posted February 21, 2008 it will if you get the right one because of the way it splits the 2 polaritys from the lmb Quote Link to comment Share on other sites More sharing options...
ivan Posted February 21, 2008 Share Posted February 21, 2008 Whatever you choose you will still need two feeds from the communal box down into your flat. Quote Link to comment Share on other sites More sharing options...
adam bell Posted February 21, 2008 Share Posted February 21, 2008 correct,thats why the communial system will have more outputs for sky plus use Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted February 21, 2008 Share Posted February 21, 2008 I think my bro-in-laws flats only had switching and wiring for one per flat but have or maybe will be upgrading. Quote Link to comment Share on other sites More sharing options...
imi Posted February 21, 2008 Share Posted February 21, 2008 Whatever you choose you will still need two feeds from the communal box down into your flat. why? correct,thats why the communial system will have more outputs for sky plus use maybe - i will check with them. Quote Link to comment Share on other sites More sharing options...
