Boost Gauge Fitting
Adam Kindness
For the hole in the bulk head...as you have an auto you can use the manual clutch resevoir's route through the bulk head.
Basically behind the turbo's below and to the right of the brake resevoir you'll find a grommet in the bulk head.
(doh - Steve got there first)
Guest Martin F
I would expect a bit higher than that, say about 0.7, 0.8bar.
Try putting your foot flat to the floor in top gear going up a hill or incline and see what max boost is.
I use to have the same Blitz Boost Gauge as Adam's fitted in my car in the very same position. I've just replaced it now for a 60mm one on the A-Pillar so the old one (12months) is going spare if anyone wants it.
First to shout can have it for the cost of the postage.
Nic
