Stu_Fraser Posted November 2, 2004 Share Posted November 2, 2004 Ive removed the first cat on my Jspec TT and im hitting a constant 15psi Im now going to remove the second cat and fit a restrictor ring to keep the boost at about 1.2bar. Will the stock fuel map's cope with this amount of boost or will it be worth fitting an uprated fuel pump for long term piece of mind Link to comment Share on other sites More sharing options...
Jake Posted November 2, 2004 Share Posted November 2, 2004 1.2 bar will be just about ok *IF* your existing stock fuel pump is working 100% I'd get an uprated Walbro or similar just to be on the safe side. When I went on a dyno I found out that my decatted RZ was running dangerously lean at high boost due to the 10 year old pump being a bit tired. Link to comment Share on other sites More sharing options...
Robert Posted November 2, 2004 Share Posted November 2, 2004 to be honest it would be better for the soop if you added an uprated guel pump such as a walbro one. this is so you dont hit detonation on full boost.i jsut got my soop fully decatted and i got a walbro fuel pump and emanage. its better to have some confidence your not doing any damage when u put your foot down. Link to comment Share on other sites More sharing options...
Stu_Fraser Posted November 2, 2004 Author Share Posted November 2, 2004 Thanks guys, thats what i thought, its better to be on the safe side, so uprated fuel pump and second decat it is then Link to comment Share on other sites More sharing options...
Faith Adopter Posted November 6, 2004 Share Posted November 6, 2004 but what about a FCD? wouldn't you also need to add one of these?? Link to comment Share on other sites More sharing options...
Stu_Fraser Posted November 6, 2004 Author Share Posted November 6, 2004 Already got one mate Link to comment Share on other sites More sharing options...
Robert Posted November 6, 2004 Share Posted November 6, 2004 yea you will need a fuel defence cut or emanage ( emanage is better as yu can alter the ignition timing aswell) Link to comment Share on other sites More sharing options...
Jake Posted November 6, 2004 Share Posted November 6, 2004 An e-manage would be overkill and unnecessary expense for Stu's proposed setup. Link to comment Share on other sites More sharing options...
Robert Posted November 6, 2004 Share Posted November 6, 2004 yea jake that might be a good point for now but just say in the future incase he wanted to add anymore mods then he would need to upgrade to emanage from fcd anyway Link to comment Share on other sites More sharing options...
dude Posted November 6, 2004 Share Posted November 6, 2004 The E.manage isnt an upgrade from an FCD its a massive step that needs a lot of setting up to get right , his first step should be a walboro and a decent regulator to be on the safe side . Dude:flame Dev Link to comment Share on other sites More sharing options...
Faith Adopter Posted November 7, 2004 Share Posted November 7, 2004 "his first step should be a walboro and a decent regulator" Dude, what does the regulator regulate (and how much £) is this deff. neccesary, only I am thinking of a similar setup and want to make sure everything will run sweet:cool: Link to comment Share on other sites More sharing options...
dude Posted November 7, 2004 Share Posted November 7, 2004 Originally posted by Faith Adopter Dude, what does the regulator regulate (and how much £) is this deff. neccesary, only I am thinking of a similar setup and want to make sure everything will run sweet:cool: The regulator regulates the fuel pressure dude , the advantage of an adj.one is that you can tweak the fuel pressure to suit your needs , you can fit a small guage to the front so you can moniter pressure at any time , the FSE is a rising rate reg , meaning that the fuel pressure will rise at a faster rate than a stock reg which is handy if you are trying to max the 440's , for every other application IMO id go for a Aeromotive or if your very flush a Wealdon . Dude:flame Dev Link to comment Share on other sites More sharing options...
Guest scw02102 Posted November 7, 2004 Share Posted November 7, 2004 where could i get a cheap HKS Fuel Cut defender from? Link to comment Share on other sites More sharing options...
Stu_Fraser Posted November 8, 2004 Author Share Posted November 8, 2004 The plan is: Uprated Fuel Pump Uprated Fuel Pressure Regulator Full Decat 1.2bar boost :D Link to comment Share on other sites More sharing options...
