Crank pulley question
Shane
not sure exactly what distance you are after but here some rough measurements.........
35mm centre whole diameter
15mm from the edge of this hole to centre of small holes
65mm between centre of each of the small holes.
so 32.5mm from the centre point to each small holes centre........
i'll stop now as i'm not sure i'm being too clear!!:D
