Bleeding master cylinder
Dave F
From the manual: :)
If the master cylinder has been disassembled or if the reservoir becomes empty, bleed the air from the master cylinder.
(a) Disconnect the brake lines from the master cylinder.
(b) Slowly depress the brake pedal and hold it.
© Block off the outer holes with your fingers, and release the brake pedal.
(d) Repeat (b) and © 3 or 4 times.
