coolant
gavin.starr
just bought my self a new ally rad for my supra, just wondered what type of coolant to use as there are two different types of coolant ?. and also where abouts is the thermostat hidden as i may as well change that at the same time dependant on what its condition is.
cheers in advance
gav
ps. twin turbo import manual.
rito cheers for that my mate works at renault so he can get us siht loads of the red but not the green coolant for soom reason so that well good to hear.
where about is the thermostat housed im totaly new to toyotas used to be a vauxhall man. is it near the top pipe where it comes out of the top of the engine? if u catch my drift
the thermostat is in the bottom hose, right near the alternator. It's a bitch to get at unless you take the alt off (if you have big hands like me). Also, make sure you get a proper seal when putting it back together or it will leak and thats the most annoying thing EVER! (I kept catching a small cable in there but couldn't see it)
I'd change it for sure when changing the rad after my problems (new engine required!).
Oh, and as stated, Toyota 4-life coolant (red) is the way forward.
EDIT wooo 2000 posts lol :)
