gavin.starr Posted July 31, 2007 Share Posted July 31, 2007 just bought my self a new ally rad for my supra, just wondered what type of coolant to use as there are two different types of coolant ?. and also where abouts is the thermostat hidden as i may as well change that at the same time dependant on what its condition is. cheers in advance gav ps. twin turbo import manual. Quote Link to comment Share on other sites More sharing options...
Joeatphr Posted July 31, 2007 Share Posted July 31, 2007 Gav, I would recommend staying with the Red Coolant from Toyota, if you want to upgrade your thermostat then I would go with the TRD, keep in mind that they are getting harder to come by! Cheers, Joe Quote Link to comment Share on other sites More sharing options...
gavin.starr Posted July 31, 2007 Author Share Posted July 31, 2007 rito cheers for that my mate works at renault so he can get us siht loads of the red but not the green coolant for soom reason so that well good to hear. where about is the thermostat housed im totaly new to toyotas used to be a vauxhall man. is it near the top pipe where it comes out of the top of the engine? if u catch my drift Quote Link to comment Share on other sites More sharing options...
Joeatphr Posted July 31, 2007 Share Posted July 31, 2007 It may be a bit different with the J-spec but if you will look where the piping goes off your Rad. you will see a pipe connected to the block that will house a thermostat. Pretty simple I would say to find! Cheers, Joe Quote Link to comment Share on other sites More sharing options...
gavin.starr Posted July 31, 2007 Author Share Posted July 31, 2007 cheers bud most apreciated Quote Link to comment Share on other sites More sharing options...
edge Posted July 31, 2007 Share Posted July 31, 2007 Have a look at this http://www.mkivsupra.net/vbb/showthread.php?t=113724 Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted July 31, 2007 Share Posted July 31, 2007 the thermostat is in the bottom hose, right near the alternator. It's a bitch to get at unless you take the alt off (if you have big hands like me). Also, make sure you get a proper seal when putting it back together or it will leak and thats the most annoying thing EVER! (I kept catching a small cable in there but couldn't see it) I'd change it for sure when changing the rad after my problems (new engine required!). Oh, and as stated, Toyota 4-life coolant (red) is the way forward. EDIT wooo 2000 posts lol Quote Link to comment Share on other sites More sharing options...
gavin.starr Posted July 31, 2007 Author Share Posted July 31, 2007 cheers for ure help fellas shall keep u informed on the progress as i need it done asap as im off down to newque on thursday for a mad ass tw0 week camping trip cant wait cheers again gav Quote Link to comment Share on other sites More sharing options...
