IT Bods - Exchange 2003 public information store corrupt! What do I do???
edd_t
One of our public information stores is corrupt, so we cant mount the database. I've got a ton of angy uses with out e-mail! ahhhhhh.
When I mount the store I get the following error:
The database files in this store are corruped.
ID no: c104173b
Exchange System Manager
The knowledge base doesnt seem to have info on that ID number!
In the even viewer I get this:
Information Store (4708) First Storage Group: The database page read from the file "M:\EXCHSRVR\mdbdata\priv1.edb" at offset 26745671680 (0x000000063a2a9000) (database page 6529704 (0x63A2A8)) for 4096 (0x00001000) bytes failed verification due to a page checksum mismatch. The expected checksum was 3949998620039364478 (0x36d136d122babf7e) and the actual checksum was 8189920891379784918 (0x71a871a89d3e1cd6). The read operation will fail with error -1018 (0xfffffc06). If this condition persists then please restore the database from a previous backup. This problem is likely due to faulty hardware. Please contact your hardware vendor for further assistance diagnosing the problem.
Have run a checksum and the results are so far:
C:\Program Files\Exchsrvr\bin>eseutil /k "m:\exchsrvr\mdbdata\priv1.edb"
Microsoft® Exchange Server Database Utilities
Version 6.5
Copyright © Microsoft Corporation. All Rights Reserved.
Initiating CHECKSUM mode...
Database: m:\exchsrvr\mdbdata\priv1.edb
Streaming File: m:\exchsrvr\mdbdata\priv1.STM
Temp. Database: TEMPCHKSUM2604.EDB
File: m:\exchsrvr\mdbdata\priv1.edb
Checksum Status (% complete)
0 10 20 30 40 50 60 70 80 90 100
.........................ERROR: page 6529704 checksum failed ( 0x36d13
6d122babf7e / 0x71a871a89d3e1cd6 )
12722034 pages seen
1 bad checksums
0 correctable checksums
20162 uninitialized pages
0 wrong page numbers
0x72af9f3f highest dbtime (pgno 0x1a44fd)
795128 reads performed
49695 MB read
495 seconds taken
100 MB/second
506757043 milliseconds used
637 milliseconds per read
153079 milliseconds for the slowest read
0 milliseconds for the fastest read
4842496 pages seen
0 bad checksums
1656585 uninitialized pages
Operation terminated with error -1206 (JET_errDatabaseCorrupted, Non database fi
le or corrupted db) after 674.766 seconds.
Anyone got any ideas? I really don't want to do a restore...
Can you restore the file from a backup. People may lose a few emails but at least it might mount the database OK.
Any ideas on how the file got corrupted? It may just do it again if the disk or memory is flakey.
i could restore from backup, i've save the transaction files so not many e-mails would be lost.
but first of all im running:
eseutil /p priv1.edb
so its running repair mode but still scanning the database. ahhhhhhh its gonna take ages!
not sure how it got corrupted. hardware seems to be fine. but i'll do a full investigation into that tommorow.
Ive had this happen before on a Cluster. In our instance it was due to the Q drive being unpresented from the SAN by the storage manager. We eneded up restoring from the last backup. I would recommendation restoration from the last backup especially if you have the transaction logs. The hard recovery can sometimes be a little too harsh and you will prob end up with loads of users that can see the summary of mail items but when they go to get the full item they get an error due to the data being missing.
Looking at the event log entry my moneys on a failed disk write (bad disk or high queuing causing a discard) causing the corruption ... BTW Microsoft have some new Exchange Server performance analysis tools out, so give them a run and see what reports back.
EDIT: I see you've run eseutil /k ... have you tried the /r option, yet (with a log prefix, and /i)? Get a flat file backup of the database and logs first.
Hang about - are you saying that your users store and PF store are in the same storage group, and because the PF store is corupt, the users store won't start?
oops no. meant to put private store there...
all is working again now. cant remeber the exactly what it said but something to do with the jet database thingy!
will check out the new analysing tools tommorow as no doubt someone will wanna know what happend.
im guessing its gonna be a disk fail due to high queing like u said.
we actually backup the exhange with 2 systems at the moment. the main backup is Backup Exec 11d. But we have started using a HP DS Client online backup which is still in testing mode.
Exactly the same error here, on 2 privs and one pub.edb, on valentines day (typical). I worked a 45 hour shift to get the system back :(
Micro$oft recommended migrating everything to new clean databases (just using 'move' in ESM) 'just in case', as they don't recommend using stores which have been in that state in production. That did isolate the problem mailbox(es), though.
Turned out that somehow we had most of the logs and databases running off one drive (NOT how I config'ed it originally!) which killed the disk throughput. And an av trying to scan the edbs. *sigh*
EDIT: Should we try to somehow relate this to Supras, given the nature of this forum? "You know, Paul, running an Exchange cluster is much like driving a supra ..."
