Garaged
Manic
Also remember to move the car backwards and forewards so that (a) you can use your brakes to wear off the oxide layer on your brake discs and (b) you can rest your car on a different part of the tyre as to not cause any permanent deformation of the rubber.
Give it a battery re-charge top up every three weeks (depending on how much drain your alarm systems creates you may have to do a re-charge top up every two weeks in the cold eather).
I've also put some rust protector on the under-side of mine whilst it will be in winter storage. Its a spray-on water disperser with a waxy type of additive. So it will protect against moisture in the air attacking the suspension and metal parts (even body-work).
