dangerous brain Posted August 1, 2007 Share Posted August 1, 2007 Right so a 4088 isnt exactly the power house i thought it was gonna be? I've been offered a whole helluva lot of turbo's of late including a t04z with various trims. I am lost on where to spend my money now. The only advice I am really getting is from an ebay trader. He is telling me I can get a turbo of a t04z variety in an ar of my choice for a very good price. Now I have to figure out what AR's I need. Link to comment Share on other sites More sharing options...
Sean1933 Posted August 1, 2007 Author Share Posted August 1, 2007 so it seems the standard rail with drop in 650cc's is the way to go then! Link to comment Share on other sites More sharing options...
Jake Posted August 1, 2007 Share Posted August 1, 2007 Jake, you don't have a stock bottom end do you? As far as i know the bottom end is all stock. I really dunno what's in there. All I do know for sure is that it's got hks pistons, other than that your guess is as good as mine. Link to comment Share on other sites More sharing options...
dangerous brain Posted August 1, 2007 Share Posted August 1, 2007 Seems that way yes Link to comment Share on other sites More sharing options...
Jake Posted August 1, 2007 Share Posted August 1, 2007 Right so a 4088 isnt exactly the power house i thought it was gonna be? I've been offered a whole helluva lot of turbo's of late including a t04z with various trims. I am lost on where to spend my money now. The only advice I am really getting is from an ebay trader. He is telling me I can get a turbo of a t04z variety in an ar of my choice for a very good price. Now I have to figure out what AR's I need. That's right, it's not a monster turbo, it's a good cheap street turbo. Tried and tested both here and in the US. I couldn't care less if Alex and Homer want to have digs about it being a truck turbo, blah blah. I think they're great. (The turbo I mean, not Alex and Homer) Way better suited to the Supra engine than the PHR1 GT60 I had before. I'm not trying to twist your arm though Bry, do what you like mate, makes no odds to me either way. so it seems the standard rail with drop in 650cc's is the way to go then! That's what I'd do My Blue VVTi actually has 800cc PE injectors in the stock rail but they're getting an easy life. They seldom see over 60% duty cycle iirc. Link to comment Share on other sites More sharing options...
Sean1933 Posted August 1, 2007 Author Share Posted August 1, 2007 so 650cc's wont max out with the GT4088...looks like thats what im getting then! thanks all Link to comment Share on other sites More sharing options...
b_have Posted August 1, 2007 Share Posted August 1, 2007 so it seems the standard rail with drop in 650cc's is the way to go then! Thats exactly my setup mapped by RyanG on Sunday. Hit 1.52 bar @11.7 today. Link to comment Share on other sites More sharing options...
Homer Posted August 1, 2007 Share Posted August 1, 2007 Can someone please confirm asap if PE 650cc in a stock rail (conv to twin feed) will be able to happily support a GT4088 at 1.4/1.5bar. Or should i get 688cc delphi (my contact confirmed he can get for 250quid) and an uprated rail? works out about the same price either way...Need an answer asap. Cheers If I've understood it correct, the GT4088 is about on par with a T67 in terms of it peak flow. When I was discussing injectors for the T67, Ian C said: My 720's at 38psi static run around 85% to 90% duty at the top end of the rev range and 1.4bar boost. 650's are fine for a T61 at 1.4bar, maybe 1.6 if you crank up the fuel pressure, but you'd see 98% to 100% duty at 1.4bar on a 67, leaving absolutely no headroom for the boost creeping up a bit or running richer in higher gears for intercooler effects etc etc so frankly I wouldn't map that high, maybe 1.2bar maximum. So, the answer is probably a No, they will not safely flow enough to run a Gt4088 above 1.2bar. *waits to be corrected* Link to comment Share on other sites More sharing options...
Homer Posted August 1, 2007 Share Posted August 1, 2007 Thats exactly my setup mapped by RyanG on Sunday. Hit 1.52 bar @11.7 today. Do you know the FP and duty cycle? Link to comment Share on other sites More sharing options...
Jake Posted August 1, 2007 Share Posted August 1, 2007 Thats exactly my setup mapped by RyanG on Sunday. Hit 1.52 bar @11.7 today.What turbo though? Link to comment Share on other sites More sharing options...
Sean1933 Posted August 1, 2007 Author Share Posted August 1, 2007 Christ im confused...dont know what to do now. Just said to someone i would have there new PE650's off them...but if the cant take my expectations....HELP-CLARITY PLEASE!? Link to comment Share on other sites More sharing options...
Homer Posted August 1, 2007 Share Posted August 1, 2007 Christ im confused...dont know what to do now. Just said to someone i would have there new PE650's off them...but if the cant take my expectations....HELP-CLARITY PLEASE!? If I were you I'd have a chat with a few of the mappers and see what they say. RyanG has a GT4088 with 650's so would be a good starting point. Link to comment Share on other sites More sharing options...
Sean1933 Posted August 1, 2007 Author Share Posted August 1, 2007 If I were you I'd have a chat with a few of the mappers and see what they say. RyanG has a GT4088 with 650's so would be a good starting point. Just PM'd him. Cheers mate Link to comment Share on other sites More sharing options...
Ryan.G Posted August 2, 2007 Share Posted August 2, 2007 If I've understood it correct, the GT4088 is about on par with a T67 in terms of it peak flow. Im not sure that they are i would say the gt4088 .81 is between the t61 and t67. Looking at the duty cycles calculation your t67 flow abit more at the top end to the gt4088 .81 housing. So my advise would be if your planning on running a gt4088 with a .81 housing and stock cams then 650cc injectors are fine as i run them and so does b'have in this setup. Max injector duty i have ever seen is 84% (1.5bar) on cold night but normally around 80% which is fine. If your planning on running a t67 or gt4088 .96 housing then i would go for some 720cc or 800cc. Also if your planning on running a gt4088 .81 with some aftermarket cams i would also recommend getting some 720cc injectors or raising fuel pressure with 640cc if wanting to run more than 1.3bar HTH Ryan Link to comment Share on other sites More sharing options...
b_have Posted August 2, 2007 Share Posted August 2, 2007 What turbo though? GT4088 0.81 a/r Link to comment Share on other sites More sharing options...
Sean1933 Posted August 2, 2007 Author Share Posted August 2, 2007 If i was to use an uprated rail + siemens 780cc injectors...i assume i can still use stock FPR + lines, etc? Link to comment Share on other sites More sharing options...
dandan Posted August 2, 2007 Share Posted August 2, 2007 As far as i know the bottom end is all stock. I really dunno what's in there. All I do know for sure is that it's got hks pistons, other than that your guess is as good as mine. OK fair enough - seems to be holding together alright though doesn't it? I guess TJ did a better job than most people would give them credit for. If you've got HKS pistons though then the bottom end isn't stock. Link to comment Share on other sites More sharing options...
Jake Posted August 2, 2007 Share Posted August 2, 2007 OK fair enough - seems to be holding together alright though doesn't it? I guess TJ did a better job than most people would give them credit for. Yeah it's holding together great. I've been giving it some serious stick on the motorways since I started working again and thanks to Ryan's map it drives great. I'd really like to ditch the lightweight flywheel and get back to a stock one but other than that I'm really happy with the car now. I've no complaints about TJ's mechanical skills. I'm not so happy about their mapping and I'm very unhappy with their customer service and business practices. If you've got HKS pistons though then the bottom end isn't stock. I don't think of pistons as 'bottom end'. To me the bottom end is the crank and parts attached to it. YMMV, seems like splitting hairs really though. Link to comment Share on other sites More sharing options...
Joeatphr Posted August 2, 2007 Share Posted August 2, 2007 I think you guys should go here and read this thread. http://www.mkivsupra.net/vbb/showthread.php?t=80054 Link to comment Share on other sites More sharing options...
Jake Posted August 2, 2007 Share Posted August 2, 2007 ***BREAKING NEWS *** MVP agree with the other traders: you really do need a multi-thousand dollar fuel kit. Link to comment Share on other sites More sharing options...
Homer Posted August 2, 2007 Share Posted August 2, 2007 I think you guys should go here and read this thread. http://www.mkivsupra.net/vbb/showthread.php?t=80054 was waiting for that thread to be quoted Link to comment Share on other sites More sharing options...
