Idle and emanage probs please help
G9RGE
Here is the story, i booked into turbofit to get my emanage maped by dan. when i got there, i realised i had forgot the actul emange unit (:innocent: i know what a prat). Well luckily Greg had one that i used to get my car mapped on and i upoaded the file to mine when i got home.
Since plugging my one in i keep gettin error code 25, which is problem with injector no 5. Ive checked all connections and continuety and all is ok. Ive fired the car up and tapped into each injector to see whether each pulse is pulsing like it should and all is ok. I dont get and engine management light coe up on the dash.
If i disconnect the field harness i get no engine management lights or error codes.
Ive since realised that the emanage doesnt flash an error when you first start up it only has a problem when the car revs drop below about 1k, ie after the auto choke stops.
Can anyone help as im stuck, all the jumper settings are the same as they were on the unit i got mapped. My unit is 2nd hand, could it be a faulty unit??
Is it also bad to be driving it with the error codes flashing, im only running low boost at 1 bar.
Please Help
