Guest tonysss Posted July 29, 2007 Share Posted July 29, 2007 Hi. I got my 1996 N/A Sup in bits. I`m trying to fit a tacho. Who knows what pin i use from the ECU?. There is a diagram here but it says pin 16..I had a look but pin 16 is blank on my ECU. I`m running out of time to fit this thing. Can any one HELP!!! Quote Link to comment Share on other sites More sharing options...
Nic Posted July 29, 2007 Share Posted July 29, 2007 This may help http://mkivsupra.net/vbb/showthread.php?t=35919 Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted July 29, 2007 Share Posted July 29, 2007 When i fitted one to mine i just spliced into the wire behind the dials going to the original tachometer... I found this loads easier than fiddling with the ecu wires Quote Link to comment Share on other sites More sharing options...
Guest tonysss Posted July 29, 2007 Share Posted July 29, 2007 Thank`s for the help. But i have looked at the diagram,and that is the problem. Pin 16 on the E10 is tacho. but on my ECU pin 16 is blank???? Quote Link to comment Share on other sites More sharing options...
